I'm just worried it might sound like shit. I guess worst case scenario, just replace the speakers with 4ohms designated for guitars.It's a solid state head, so you can plug it into a cabinet with a higher impedance. Just don't go below 4 ohms.
Using a crate SS with a bass cabinet...You cannot be too worried about it . Seems thrown together.I'm just worried it might sound like shit.
Doesn't say. All I know it's a 60 watt rms per channel at 4 ohmsIs it a class D power amp?
I'm a newb at this. I always play on solid state combo amps. This is my first attempt at throwing something together. I know its ideal to match ohms but I have heard mix reviews. I know doing the opposite of what I'm doing would be disastorus lol but I do know using a 4 guitar amp on an 8 bass cab could mean sacrificing volume and or tone. By how much I'm not sure of.Doesn't say. All I know it's a 60 watt rms per channel at 4 ohms
You won't sacrifice volume because you will probably never run the thing at full volume. The tone is already going to be different because you are using a bass cabinet instead of a guitar cabinet. I would find a way to turn off the tweeter, that would be the thing that might get fried if you use distortion. The speakers in that cabinet will probably be a little cleaner than ones you would normally find in a guitar cabinet.I'm a newb at this. I always play on solid state combo amps. This is my first attempt at throwing something together. I know its ideal to match ohms but I have heard mix reviews. I know doing the opposite of what I'm doing would be disastorus lol but I do know using a 4 guitar amp on an 8 bass cab could mean sacrificing volume and or tone. By how much I'm not sure of.
The tweeter has a level control on the back so that solves that problem.You won't sacrifice volume because you will probably never run the thing at full volume. The tone is already going to be different because you are using a bass cabinet instead of a guitar cabinet. I would find a way to turn off the tweeter, that would be the thing that might get fried if you use distortion. The speakers in that cabinet will probably be a little cleaner than ones you would normally find in a guitar cabinet.
Yeah I pretty much figured it out that it will be fine. This made me flashback to the time when I was a kid, I wired a shelf speaker to a clock radio thinking it would be louder but the result was the volume level pretty much stayed the same and the speaker wasn't working to its full potential. I don't plan on cranking it to ten so volume will only be a slight factor but not noticeable unless you're a gear snob. I pulled the trigger and bought the cabinet. Its not going to destroy the amp so what the hell lol.Get a grip! Plugging up amps and speakers is what I did in school physics classes, it is a great explanation of how Ohms Law works. A 4 x 10” cab is brighter than a 4 x 12” cab. The higher impedance causes a mismatch reflected in a small volume loss, so to get a louder sound involves turning the amp up louder than you normally do, but if you run at say, 3 on the volume knob, you might run at 5. That’s it. You might like or loath the sound. Plug it in and play. Back when we had amps with valves as the norm, everyone was experimenting with different speakers, and less good mismatches were common. The folk who did spinal tap with settings on 11 had unreliability issues. The rest of us didn’t. Solid state took away much of this. Many musicians are idiots by design, bass players like me even more so. We yank out speaker plugs by falling over them, jacks shorting the output as they pull out, we have jack’s that fall out of the guitars, treating audiences to full output of hum and cracks, and because of paralleling speakers we often have too low an impedance. If amps were delicate and unprotected, nobody would give them a years warranty, let alone the three years often offered. Nobody reads instructions so any statement of doom and gloom means you bought a previous delicate amp, or the maker just wants you to at least try to not abuse it. Most amp designs nowadays sense mismatches, throttle back output and don’t teeter on the edge of destruction. I just don’t understand the scared-e-cat mentality nowadays. Nobody ever plugs anything in until at least thirty strangers on line say it’s ok to do so, and half of these have never done it in their lives, and seem to have flunked physics classes. In truth, we’re recording folk, but if you go on a bass forum, for example, this question would now be forty pages long and wildly out of control. Here, all we really care about is what it sounds like!
