F
fonts
...anyone care to explain why these are a good thing...they seem cheap enough...
Michael Jones said:I've kind of wondered this too, and I still need convincing that I need one.
With my DAW, I can route any input, to any track/channel, to any output.
I guess the point is to be able to route say, the mic pre's that go to the live room, over into the drum room???
Well, I have more than 2 pre's. But what's wrong with say, having 4 pre's hard wired to the live room, 6 to the drum room, and 2 to the vocal booth? (All outboard pre's) Why would I ever need to change that?regebro said:Well, yes and no. The point is that the mic pres should not go to "a room". The point is that you want to be able reroute anything to anything without having to grope blindly behind your rack.
If all you have is a DAW and two preamps, no then you don't need a patchbay.
I see your point.regebro said:...So the whole idea of having a fixed set of mic preamps for each room, although not really wrong, its' well, strange. Really, really strange.
Michael Jones said:I see your point.
But if 95% of your tracking is done with 6 (or 8) mics on the drum kit, and your drum room is dedicated to drums, is it really worth it for the odd occassion that you might want to do something different??
) works.Except for another set of connections to run through.regebro said:IMO, yes. Because it's really not much more expensive or complicated to set up. You don't lose anything by using patchbays.
Michael Jones said:OK, fair enough.
I'll use a patch bay.
Normaled, half-normaled, balanced.....?
1/4"?, TT?
What?
MikeA said:For what you are building I would definitely go TT. You get a LOT more connections in the same amount of space.
Check out the homerecording article about patchbays here:
http://www.homerecording.com/patchbay.html
Here's another pretty good article too.
http://www.jimmyether.com/rec/tips/studiowiring.html
and for good measure, here's another one.
http://www.apocalypse.org/~matthew/resources/rackwire/patchbay.html
...If you need help with it Michael PM me. I helped another guy here on the forum out a few months ago. It's easy to do if you lay it out in Excel.
How's your place coming by the way? I haven't been over to John's site lately to check on your progress although I did see your doors! Very cool...
Michael Jones said:I did an update at John's site a few weeks ago... new pics there if you haven't seen 'em yet.
fierojoe said:What is the address to John's site?
