U
		undermind
Member
I just got a Neumann 472-2 (V-72 follower) dual channel preamp rackmounted and was doing some troubleshooting.   I was having some problems with it until I realized that some things were just installed backwards.
But the big question I have comes from the phantom power voltage on the mic inputs. Expecting to get 48v on the mic inputs, I actually got 110v. I got mad and thought there was a big problem until I checked on my other pre, a Trident S-20. Exact same reading, 110v. I thought maybe my multimeter was screwed up so I double and triple checked my settings, then tested on a wall jack and got 120 out of the wall. I also checked the reading at the power switch to the preamp before the power supply, same. So I think the readings are accurate.
I checked on pins 1+2, then pins 1+3 on the mic inputs. I got nothing keeping the red (positive) lead in pin 1 while moving the black (negative) from 2 to 3. So these readings were based on the black lead in pin 1 and the red lead in pin 2 and then 3. Same reading both places.
