J
jaynm26
What is your peak & average levels when recording?
My
Peak, -14dBFS
Average, - 18 dBFS
My
Peak, -14dBFS
Average, - 18 dBFS
Here's the thing, the peak to rms ratio is going to be different with every instrument. Going for an RMS of -18dbfs is a great idea, but if you are recording drums, the peak will be clipping by the time you get -18db rms.
I tend to record around -18dbfs rms and just let the peaks fall where they may. If something is getting too close to clipping, I back off the gain until it gets down around -4 to -6dbfs and get on with my life.
I swear, five years ago it would've been "As close as I can get to full scale without clipping on everything" and I would've been pulling the rest of my hair out if I had any that I could actually grab...
I pay no attention to where my levels come in at. As long as it doesn't clip, I'm fine with it.
I've no idea where the levels are when I record. On my DAW the recording level is set by the preamp knob and it just has a load of dots running in clockwise fashion from 7 to 5 o'clock. So depending on what I'm recording, I just make sure it doesn't clip. Sometimes I go for a high level, sometimes I go for a low level. It's all moroccan roll to me in the long run and it's also now 2013.So when recording the only thing that matters is the peak level. If the level is large enough to exceed the recording medium's noise floor, and not so loud it causes clipping anywhere in the signal path, then you're good to go.
I think you mean 0dbVU.
OH. Are they not the same thing? (0dBu and 0dbVU)
No, most pro audio gear is calibrated that 1.228 volts = +4 dBu (line level) where you reach the point of maximum S/N performance with minimum THD and reads as 0VU on the meters. As you push into the headroom you may get added THD depending on the circuit
If your converter is calibrated that +12dBu is maximum input level and = 0dBFS, then line level (+4dBu) or 0VU would read on your DAW meters as -8dBFS. so if you want to be recording at line level you should be shooting for RMS levels of -8dBFS which doesn't leave a lot of headroom
If you are not using any outboard gear with peak performance at line level ahead of the converter (I'm assuming the preamps are built in to the interface) the you really shouldn't have too much of an issue where ever you decide to set your levels so long as you do not clip
what do you mean by dbfs cuz im using an old 1982 12 channel studio master console
through the computer i run mine at around -10 or -7 V
