			DiodeMcRoy
I don't think there is anything wrong with your mic or interface. As rob aylestone mentioned, they are more common on snares, toms, guitar cabs etc, which is what I use them for.
I've been using a 57 lately, on a 4 x 12 Mesa cab, driven with a 50W Marshall 1987 knockoff, and it is freaking loud. I still have to bring the gain up to about 2:00 on the preamp.
I've just never recorded quiet (relatively) sound sources like an acoustic with an SM57 as I will usually choose a condenser.
Even with the gain pinned, if the noise isn't horrible, I wouldn't worry about it. I think you are operating within the parameters of your gear. I can verify if you like. I can plug an SM57 into a preamp with 65dB (API 512C) of gain, and record an acoustic. The knob should be at about 3:00 to 4:00 for a decent level (-6 to -3dB) is my prediction.
I wouldn't let room treatment steer you away from a condenser mic. Condenser mics are much more sensitive then dynamics, for sure, but they do capture quiet sources better. You can get a pretty good condenser for under a $100 these days (or $10,000, depending on your budget). At the end of the day though, it's what works best for you and the track. If the SM57 does the job, stick with it.
I'm not sure what your concerns are regarding compression.
Here's a video you might enjoy:
EL
Thanks for your insights. Actually I bought the mic very recently and might have be misleaded but what I read on forums etc... I mean I probably can be right but for the kind of recording I wanna make (mostly quiet vocals and fingerpicking style, like travis picking, maybe some strumming, I'm more into producing folk or some light pop) maybe that's not the most ideal. And the Thomann policies allow you to get a refund until 30days after receiving it, I'm still in this window. So maybe I should send it back and get a condenser instead?
Yeah I mean Bon Iver , Sufjan Steven and Unknown Mortal Orchestra have all recorded their earlier album with some Sm57 or 58, but maybe that would be less anoying for me in my workflow to get a condenser mic instead. I'm not sure about the AT2020, I see it a lot.
Since I plan on layering a lot with som synths etc and putting the guitar a bit back in the mix, maybe the room will not be such an issue (I mean it's not super reflective, but there's the fans of my pc, some birds outside...).
But when I tried to edit the SM57 with compression etc, the noise became way too noticeable, and a noise gate is a bit annoying to set without getting some artifacts. Well not sure if it would be better actually with a condenser actually!
