J
		jjjtttggg
This may not be an entirely appropriate question for a songwriting forum, 'cause i just want to record a cover this song, but I'm hoping somebody here might be a more formal musician than me and able to help.  I cannot figure out the very first chord of this early Jackson 5 song (one of the best bass lines in the history of the universe! thank you James Jamerson).
YouTube - Jackson 5 Darling Dear
The chord progression once past the intro is (I think):
Cm7 Ebmaj7 Bbmaj7 Bbmaj7
Cm7 Dm7 Cm7-Ebmaj7 Bbmaj7
Dm7 Gm7
Dm7 Cm7 Bbmaj7 F
Dm7 Cm7 Bbmaj7 F
Even the intro seems to follow something like this pattern except that I cannot figure out the first chord. It appears several times in the intro. Seems like it should be Cm7 but has an F in the bass line. Cm7 / F can't be right can it? Doesn't sound quite right.
Anybody with a good ear for figuring out chords care to have a listen?
Thanks,
J
Dm7 Gm7
Dm7 Cm7 Bbmaj7 F
Dm7 Cm7 Bbmaj7 F
Thanks,
J
		 ). In chordal theory, the first inversion has the 3rd in the bass (not the chord root note), and the second inversion has the 5th in the bass (again, not the root). These two are the most common but there are others, and they open up many new chordal options and sound textures. Examples are G/B (first inversion--G chord with the 3rd, B, as the lowest note) and D/A (second inversion--D major chord with the 5th, A as the lowest note played). They create movement, and are handy to aid smooth transition from chord to chord. An example progression would be G to G/B to C. An easy way to experiment with inversions on guitar is to take a simple major or minor barre chord and play only portions of the barre. Instead of starting your strum with your lowest string, drop to the next one.
