Telegram Sam
So tonight I was trying out some cleaner settings on a few of my amps...and decided to record some clips of each trial.
I used the same guitar, a reissue Hagstrom Super Swede, which has a coil split switch. I recorded each amp/channel with the split coil and with it at full humbucker setting. I used the neck pickup for all.
Also used the same mic (AKG D1000E) for each clip, and positioned it in about the same spot for each amp/speaker...off center about 2", kinda midway between the center and edge of the speaker.
I can give specific amp settings for each if anyone wants them...but it may not mean anything to anyone unless they have the same amp(s).
Here's the clips...as I said, I was going more for a cleaner sound, though there's a touch of breakup on some of the clips. I also normalized each of the clips so that their levels were as close as possible.
The Chubster 40 has two channels, and I tried to set them so they were similar/balanced, but so you can still hear the different voicing of each.
With the Hammerhead, there are several tone voicing options, I just picked one that I liked for these clips.
The Rt. 66 is a basic Treble/Bass/Volume amp...so I set all three in the same position.
I played the same few chords for each clip, that way it would be easier to compare them (sorry for a few sloppy strums...my hand got tired holding the same chords over and over.
Split Coil clips
Rivera Chubster 40 - Channel 01
Rivera Chubster 40 - Channel 02
Carr Hammerhead
Dr. Z Rt. 66
Humbucker Clips
Carr Hammerhead
Dr. Z Rt. 66
I may the same thing with some OD settings on each amp when I get a chance.
Nice clips Miro, that was a lot of work.
How do you like the Dr. Z?
I think you would like a Fender amp,
what are you wanting squeaky cleans for?
