minerman
Tonetard
Thanks for taking the time to listen to my clips & give your thoughts dude......
Not sure if the T15 will take EL84's or not, are they the same pin thingie as the 6V6's & such??? If so, I can just plug-n-play if I ever get a set, if not, I'm outta luck, as I really wouldn't wanna mod the little amp, hell, I can barely solder a p'up wire...
You may be onto something about the power tubes though man, I'm gonna have to do some searching & see....I'm pretty sure the guys in the Marshall forum have mentioned using 'em....IIRC, most didn't like 'em, they preferred the 6P3S tubes, but that wasn't slaving another amp into it either....
The sound does flub a bit on the last clip, & the low end is a little better IMO, but, are you ready for the bomb???
The last clip was Amplitube 3 dude, just my Ibanez plugged straight into my interface. Of course I did some tweaking, but the tone is:
Ibanez > interface > AT3
I did use the rack eq in AT3 to get rid of some of the fizz, but I didn't even use a high pass/low pass filter, just the rack eq in AT3. I think it's pretty close, even for an ampsim. I've noticed in a lot of clips of real amps, there's some fizz in those too, & before I always tried to get rid of all of it, I think that's why my direct tones weren't as convincing to be honest....could be anything really though....
And yes, it is an interesting exercise to be honest, but by no means is it a waste of time to me, I'm learning how to get better tonez dude!!!!
