knightfly
GrouchyOldFartOnBatteries
For more cloud (and other acoustic DIY) ideas, check out this
http://www.johnlsayers.com/phpBB2/viewtopic.php?p=41783
Steve
Steve
knightfly said:For more cloud (and other acoustic DIY) ideas, check out this
Steve
NL5 said:OK, ok, ok....
It's super simple. I went to Lowes and got 3.5" mdf trim. Take that and make a frame exactly the size of your 703. Then frame the frame with another strip of the mdf trim 90 degrees from the first. Here is a pic. If it's still unclear, i can try and explain better. I also bought a 12 volt halogen light kit from lowes. Drilled 5 holes 2 1/8" in the trim and mounted the lights.
VSpaceBoy said:So if I'm reading this correctly, there is a 3.5" or so of airspace between the 703 and the side of the frame? That airspace is where the lights are located? If thats the case, is there a backing to this that the 703 is mounted to?
Gotcha, thats good to know!knightfly said:Ron, it ain't the volts; it's the WATTS. (1 million volts, with no current, causes no heat whatsoever - til some fool grabs hold of it, that is... :=))
Just make sure that any lighting fixtures you use are RATED for SEALED use IN CONTACT WITH fiberglass insulation, and you'll be fine... Steve
sonar acoustics said:NL5,
Very nice work! If you agree, I will use your pics for my students (room acoustics and design). I don’t take pictures of the studios I do… and I never thought of speaker soffits done that way (removable!).
The angles of the side walls, have you opened it enough to redirect side reflections to the rear of the room?
Mike
pandamonk said:Doubt it. That rooms is designed to be a control room. Where are your recording rooms, and how are they set up NL5?
What? I don't have a clue what you're talking about/think we're talknig about.cello_pudding said:ah...so you just run a cheap mic into their headphones?
