Starting construction on new CR!
  • Thread starter Thread starter NL5
NL5 said:
Update -
Got the soffits covered with 3/4 birch plywood. Taped and mudded the sheetrock. Built the cloud frame. More pics tommorow.......
Looking good so far man. Where are you gonna house the computer? How did you get that door for $100?
The computer is going to be inside a door in the righthand side sheetrock wall. There will be a fairly large cavity there that will house the comp, and I am going to build a fairly large rack there as well....
The door was a custom order door (and then returned) that was clearanced priced to $200, then $100. I wasn't palnning on getting a door for awile, but I couldn't pass this up. It's a 36" exterior door with a 28x60 window in it. I was going to spend $279 on a similiar interior door. :D
Walls up and soffits faced -
does look good...is it just a mixing room or do you track there as well
  • Like
Reactions: apl
Call me crazy but won't sound bleed through the gap above those soffits and cause a bunch of rumble and mud in the 2x6 section of the room you left alone. did you put any deadening material in there or do you plan to seal off the gaps?
This is looking tremendous, make sure you keep posting pics!
Mixing only - I have a 1000 sq. ft. tracking room.
It will be sealed, and will be about 1/2" from the cieling before it is sealed anyway. It will be more sealed from the area next to it, than the room next to this room anyway.
VSpaceBoy said:
Are you going to kill the ceiling?
Yes! Already have a cloud built, and will probably be installing it today. I will post pics as soon as it's up. :D
Lopking awesome Gunnar.....very cool project. What brand was that flooring?
i like the cloud. i never would have thought to put the lights in it like that. looks cool man.
Dogman, you gotta change your avatar. I spend too much time here as it is but your avatar is keeping me here even longer.
More photos!!!! AGHHHHHHHHH MORE PHOTOS..................MORE MORE MORE MORE MORE MORE
i'm learning a lot just watching this... thanks for posting pics and for the updates... looks great so far.
Looks good, keep the pics coming...However, Is that a stick on floor. If so i hope its real wood, (if its not looks good...lol) wont sound as good. Is it standard red oak?
