			DrewPeterson7
Sage of the Order
Hey all - haven't posted over here in a couple years, but I just moved to a new place, and I'm in the process of setting up a new studio. The room wa formerly used as a fitness room by the house's old owners, and they'd installed large mirrored panels along one of the short walls. We're not even close to fully unpacked (I also had a daughter about a month before our close date, which trying to have a kid, buy a house, and sell a house all at once was, well, dumb  ), but I figured I might as well start thinking about room design, even if it'll be a while before I can do more than set up my desk and amp.
So, from everything I know about room optimiztion (not nothing, but a lot less than a whole lot of you), your priorities in room treatment, after bass traps in the corners, are going to be your first reflection points in front of the speakers, followed by the reflection point behind the speaker on the wall behind the desk/that you're facing into from a seated position. I'm going to go out on a limb and guess that mirror is probably not the surface you want here, haha. At a minimum it also means your cable management game has to be on point, since you can pretty much see it all reflected back at you.
Curious though if anyone's had success with rooms with relatively reflective surfaces along a back wall like this - again, I'm nowhere near a point where I can play back a mix and hear what IO'm working with (and I'll be doing that before making any changes to the room, if nothing else because we have a lot more "necessary" projects before I can start in on "optional" ones like doing anything beyond throwing bass traps up to a room that I'll barely have time to use with a two month old, haha. But, as one single and not-especially-useful data point, pulling mu acoustic out of the case and jamming along a little, the room actually didn't sound all that bad, with nothing else in it. And, as a guitarist, having a mirrored wall to rock out in front of IS kinda fun and absolutely stokes my vanity, haha.
Anyway, I was always more active in the guitar part of this forum, but I'm sure there's a few regulars here I know as well, so... hi everyone!
), but I figured I might as well start thinking about room design, even if it'll be a while before I can do more than set up my desk and amp.So, from everything I know about room optimiztion (not nothing, but a lot less than a whole lot of you), your priorities in room treatment, after bass traps in the corners, are going to be your first reflection points in front of the speakers, followed by the reflection point behind the speaker on the wall behind the desk/that you're facing into from a seated position. I'm going to go out on a limb and guess that mirror is probably not the surface you want here, haha. At a minimum it also means your cable management game has to be on point, since you can pretty much see it all reflected back at you.
