Shout It Out
I dont know if I can ask this in here, but it seemed to be the right place...Can I hook up a 6 ohm speaker to an 8 ohm amp??
SouthSIDE Glen said:Whoah, hang on.
There are a couple of things you need to double-check. First, you need to check if your "8 ohm" amplifier is rated for 8 ohms only. Some amps are rated at 4 ohms and 8 ohms, some are rated at 8 ohms only. If your amp is rated for 8 ohms only I would not recommend using it to drive a 6 ohm load as you could be putting undue stress on a less-than-robust amplifier design. Plus the lower impedance load is going to have an effect on the working output wattage of the amplifier; the 8 ohm numbers for amp wattage will not be reliable in determining whether your amp matches up with your speakers OK in the wattage column.
If your amp is rated for 4-to-8 ohms, you should be OK on that side; what you'd need to do is take a look at the specified wattage ratings for that amp at each impedance level and calculate the rating that would fall in the middle. That should give you a good working approximation of the amp's rating at 6 ohms. Then you can use that number to compare against the speaker ratings to determine if you have a good match.
Typically you'll want the amplifier's RMS wattage rating to be somewhere aorund 75-80% (give or take a few percent) of the peak rating of the loudspeaker, though that depends a great deal on the discipline of the person running the amp's volume control.
G.
G.
What?shackrock said:and to put it simpler incase ya need...
basically 8 ohms on the amp, and 6 ohms on the speaker, means the amp gets extra power - taking a bit away from the speaker.
when they are matched, the power is dispersed 50/50 between the 2. thus, you are putting extra strain on your amp with a lower impedence rating on your speakers.
Farview said:What?
The amp output isn't 8 ohms, it is expecting to see 8 ohms. The amp doesn't get extra power, it puts out extra power with a smaller load.
If two cabinets on the same amp are matched, The power is dispersed equally. If you have mismatched cabinets (more than one) the cabinet with the lower impedance will draw the most power.
If this is a tube amp, You should not run a cabinet that is lower impedance that the output is disigned for. (higher impedance won't hurt anything)
If it is a solid state amp, you will probably be fine.
Farview said:What?
Do you want me to answer it a second time?Shout It Out said:It seems to me that the question is still unanswered.
COOLCAT said:Excuse , my lamens "take" on the Ohms being reduced..
but isn't it basic Ohms law...V= IxR??
so if R(resistance=ohms) reduces, I (current=amps) must go up.
HEAT is the enemy of all electronics.... and going 6ohm your adding more heat. Generally the power amps fry, but sometimes the fried power amp will send a distorted flat line to your driver and fry it out.
Put some FUSES in line......there's your basic insurance.
shackrock said:while that's true farview...i am trying to let him picture it like this (see attached gif....ha)
would you say that's not a decent way to view it simply (a thevinens EQ circuit for the amp, and the load)?
COOLCAT said:Why are you using 6ohm on a 8ohm anyway??[/COLOR]
