FrankD77
Photographer / musician
Let me start to make clear i know the danger of running a tube amp without load
Now that's out of the way.
I have 6 amps i like to switch between.
At the moment this means selecting the amp, and switching the speaker cable running to the torpedo twin.
Getting a proper amp switcher would be nice but for 6 amps getting pretty pricy. And I've been using this method for 5 years without any issues.
I've just build a new 19" rack and have one patch panel left and wanted to check if this is possible.
I'm thinking about using one output of the patch panel with a speaker cable to the torpedo and running seperate speaker cables to the patch panel. Now when i select an amp i can just use a short speaker cable to jumper the amp to the torpedo.
If all cables are suited for cab use does the patch panel work or does it have a different "value" which makes it impossible.
I know i have to be careful with tube amps but now i have no visual confirmation which amp is connected.
