Recording on a computer
  • Thread starter Thread starter barrywalsh_ie
B
barrywalsh_ie
how can u record two seperate tracks at once on a computer say guitar and bass and have them on seperate tracks?
what program are you using to record? You just need multitrack software. Lots out there, but maybe you already are using something. If not, download n-track and read the notes with it.
www.ntrack.com
H2H
You need a sound interface that can handle more than two stereo channels simultaneously.
Im using Kristal its a 16 track recorder, how can i get more tahn 1 input im using the mic input how can i get about 4 inputs?
You need to purchase a sound card that has 4 inputs on it, there is a wide selection, Do a search and find out what every one on this board recomends.
thanks i think the soundcard is what i need to get would u say i could get one for aroubd 200 euro?
Mic input?!!... :eek:
Usually you want to steer clear of the mic input as they tend to be very noisy. You should try to use your soundcard's line input instead. (You'll need a mixer or preamps or DI box to get signal up to line level) And, if you just want to be able to record 2 mono signals at once (guitar and bass are often recorded mono), you should be able to use a soundcard that can accept 1 stereo signal. Just send 1 signal in on the left channel and 1 signal in on the right channel. (If you have a mixer, it's easy to do this. Otherwise, you may need to do a little cable-making.) Then, in your software, select 1 track's input to be from your soundcard's Left Line In and the 2nd track's input to be from your soundcard's Right Line In.
Good luck! :)
-Jeff
This might be a stupid question but seeing as i dont know anything about recording yet.... Do all programmes support any type of soundcard?
not exactly, but most do support a great variety of cards. If I were you, I´d ask to the soundcard seller what programs it can work with.
Fernando
AUDIOTRAK - INCA 88 ohne Miditrak : would this soundcard work on any computer?
the only way to know if it works BW is firstly before you buy it email the manufacturer with details of the chipset and motherboard your using.
ask if your config is compatible.
try and buy on approval as well so you can return it and get your money back if it does not fit in with the pc you are using.
if you scan the net certain sound cards seem to have some problems while others dont. the first thing to do is find out what chipset you are using eg : SIS, VIA whatever and the make of motherboard.
