Solved Recording amp without "micing it up"
  • Thread starter Thread starter Mason Earley
M
Mason Earley
I am using a mixer, and I am currently using a VST amp to add amplify my guitar. I have a real amp that I am hoping to amplify my guitar with before sending the input to my computer. Micing my amp up is not an option for me personally. I figured out that I can plug my amp into the aux send, but I am not sure if that is what the amp should be plugged into that.
Also, I didn't do enough research for the mixer I got, I got a mixer for performing, not for recording (Alto Professional Live 1202). It is an amazing mixer, but not what I need, so can someone direct me to a mixer that isn't thousands of dollars that I can record with. I don't "need" it to have a usb interface, because I have an AI. Still learning.
I am not sure about the aux send because when I open my DAW (reaper) the amp starts making a high pitched noise, but it is still output the audio.
It depends on the amp. If it has "line" outs then that can be plugged into an aux. If it only has a speaker output i would not recommend it. If it is a tube amplifier it may be damaged, if it is a solid state it could overload the aux input and sound like crap.
By the way, even a line level to aux input will not sound like a mic'd up amp speaker. Doesn't mean bad, just different. Maybe very different.
You haven't told us what amp you are using. Does it have a line out or headphone out? If so, you can plug those directly into your USB audio interface. The mixer is not serving any purpose. On the other hand, if you are using the 'speaker out' of the amp - using this without have an actual load on the amp may be detrimental to it, you would need a 'load box', which would have an output you could send to your interface.
