stone_eufemia
just tested Ld Dbl.2.wav zip file, and i didn't have problems in soundforge and vegas.
Compensating for level is crucial......... yes - I set each mix for the same SPL when listening. Would be a pretty rookie move if I hadn't done that, btw!Badchi said:I agree also, now convert to an MP3 and your mix sounds like ASS, but........I just can't help myself. Maybe there's a 12 step program for limiter abuse. Anyway, if the judges compensate for volume, which I believe they all did, the advantage should go to the more dynamic mix.
ocnor said:No dice with the unzipped file. It crashes Audition and won't load into Sonar.
tenkas said:Still crashes audition and doesn't load in sonar (the non zip)
strange... but it plays in winamp perfectly
giles117 said:Now fin you should have no issues. OS X and Core Audio![]()
tenkas said:My guess is that these waves are "special" waves, generated by mac software, so they are only decriptable by mac, just like broadcast waves need special treatment (... french is my first language!!!)
giles117 said:Vestast, check the new 44.1/16bit files in the TestFolder. If there is still an issue I am totally lost.
bennychico11 said:your running PT, right fin? i'm downloading them (slowly) and tested one through Windows Media Player. It didn't work....but then it opened up in iTunes (microsoft vs. apple??) and played fine. weird
--okay, one of the files opened up in PT 6.4 fine (windows)
giles117 said:Hey Ben, you can export it from itunes (by using the convert option) to a waves file that should be compatible with your software. I had to do that with a corrupted waves file based on how the conversion works.
