K
kfalls
I work for a company who performs archiving for college media collections. We have several Tascam 122MKIII players. I've performed alignments using Gennlabs 1KHz level and 10KHz Azimuth alignment tapes. Part of out procedure is to also use the 10KHz tape to set the high frequency output. I have all four player aligned almost identically and calibrated the VU meters to read 0 at our reference output. However on one when I listen and view recorded music the right channel reads approx 3db-5db lower than the left. It reads the same on our digitization recorder. The same tape reads fine on our other players.
All I can think of is the playback head may be worn resulting in an imbalanced EQ, thus off balanced VU readings. I'm trying to find multi-frequency cassette EQ tapes like the old TEACs I used to use, but can't find what I need from MRL or GennLabs. Any ideas what is causing the VU imbalance when Level, Azimuth and High-End are aligned? Any help or comments would be appreciated.
