Porta Two Ministudio PS-P2 adaptor dead
  • Thread starter Thread starter dFletchmann
D
dFletchmann
I'm new to the bbs, have an old Port Two Ministudio used as a mixer to add tracks to my Cakewalk Pro Audio. Has anyone had experience with power input dying (either input plug dead, or PS-P2 adaptor dead)? It's a royal pain to go through batteries. Not so bad on the road for a short recording session at a school, but the pits for studio work. Thanks.
Suggestion
I haven't had this problem on this particular product, but if you have a tester you can test the power supply and see if it is working. It should be labeled with the voltage, current, and polarity so you should easily be able to find a suitable replacement for it if needed.
If the problem is not the power supply, and the unit works on batteries (which I have experienced before on other equipment), you can solder a new power jack onto the battery terminals and connect the power supply to that. It's worked for me and beats the heck out of batteries.
Just be sure that if you replace the power supply, you must match the voltage, the amperage (usually shown in milliamps) AND the polarity (which conductor is positive/negative). And if you add a jack, you must again match the polarity to that of the power supply.
Good luck!
Porta Two Reply Thanks. Need user manual
Thanks for the response. I do music, but I'm not much of an electrician. I'll check that out. The Porta Two is pretty old, but it has a lot of good features. I got it a few years ago from a close friend, who lost the user manual. So, I've been just experimenting with it, trying to figure out how it works. Any help locating a manual would be greatly appreciated.
Happy New Year.
dFletchmann
