F
fenderdude
Thanks, here are the specs for the Crown, I'll have to dig up the ones for the speakers....RawDepth said:It looks like the Crate mixer has two amps that are each mono channel. Each channel has two speaker jacks to enable you to use 2 FOH speakers and 2 monitor speakers. You are correct that each amp sees a 4 ohm load. No Problems there, I believe you have been using it correctly.
About the power concerns for the Crown...perhaps this will help. It is a good rule to follow. I believe it is very important with subs, mid-bass, and maybe hard driven mid range speakers, and a bit less important with higher frequency speakers.
You will need to dig up the power rating specs for your Crown amp and for the speakers to determine if they are well matched.
Good luck,
RawDepth
1 kHz with 0.5% THD
Stereo, 2 ohms (per ch.)
Stereo, 4 ohms (per ch.)
Stereo, 8 ohms (per ch.)
Bridge-Mono, 8 ohms
Bridge-Mono, 4 ohms
250W
200W
145W
400W
500W
