Original tune: The Honeymoon Flops
  • Thread starter Thread starter Thekesslerboy
Thekesslerboy
Thekesslerboy
Active member
First recording of a song I wrote a while back but never got round to playing in my old band, or recording it. Pretty simple, only three chords, but I had fun experimenting with backing vocals on this one. Probably overdone it, but I was playing around. Made up some things on the spur of the moment and went for some notes I had no likelihood of reaching and no business attempting! A few clumsy edits in there too as I tried to shorten it after the fact after the recording was locked. Just another bitter, twisted, loser in love song! Grateful for any thoughts.
Nine months later remix.
THE HONEYMOON FLOPS
The ceremony is over
And the circus has begun
Dared to ride the tiger,
Said “I do” and now I’m done.
Darkness has descended
And your friends have run off home
The fun and games has ended
And at last we are alone.
My heartbeat stops
My jawbone drops
Love lies bleeding on the rocks
As the honeymoon flops.
I can’t escape the feeling
That your mind is not all there
You’re studying the ceiling
Like you wish you were elsewhere
My heartbeat stops
My jawbone drops
Your humour is unusual
You’re laughing through your teeth
You put the fun in funeral
Your bouquet was a wreath
My heartbeat stops
My jawbone drops
As the honeymoon flops.​
Feels like the back up experiment worked out good. Was easy to hear all of the different parts nicely. I had a bit of trouble with the sound of the snare though, it was too sizzly and distracting. I did like the high end sizzle on the lead guitar I think that worked well
Thank you very much. The drums are just a repeat loop from the Boss BR-800. I haven't got into programming parts yet, I just set the beat, pick a pattern and play along to it. Probably about 4 guitar parts on here, not including the bass and lead. Tried to pan them over more than usual to let them breathe. I always overload things though! Thanks for listening.
Speed mix - surprisingly difficult to mix - Tell me what you think.
Wow that was quick! I like it. The drum sound is massive at the beginning, probably because you are using better production and have been doing it longer. The main vocal sounds more distorted than before. That's probably a problem with the source material. I always tend to record everything too high. I am trying to fix that in future. I have to use what EQ I can to smooth it out but am not always successful. You've certainly blended the vocals better with the backing vocals. They are where they should be - in the background. The instruments also sound a bit clearer and crisper. That's always what I'm aiming for.
Were there any obvious things you fixed that I should try to avoid in future?
Thanks for doing that. And thanks for saying you like the song. That means a lot. I'm more of a songwriter than a performer. Cheers, Papanate.
You are right about the vocals - they are distorted slightly - part of that was in the recording - but part of that was an artistic choice on my part - I’ll put another mix with clean vocals to compare - The drums I used a slight bit of compression with a Convolution Reverb to get them big - the Bass I substituted in - the Jangly guitars were distorted with the first set flat lining on the mix - I had to run it through RX11 Advanced to clean them up - I dropped the big distorted guitars all together -I EQ’d most of the parts such as the guitar and bass - bandwidth limiting them so they would walk over anything - and I aligned and somewhat tuned all the vocals to blend together right - there was a lot to do to mix it right - mostly just listening for the correct balance - and a lot of vocals to get into the mix. I will do the mix again - see what you think.
Here is the mix with vocal clean - well as clean as they will go - I took the drums into a Springsteen 1980s sound - and I took the lead guitar part and centered it instead of Stereo Spread - took down the Reverb on the vocals too - let me know what you think - It’s a Fun Song to mix - great lyrical hook - Honeymoon Flops!
Nice one! It's getting better by the minute. This is the original recording length and is over long. I cut out some repeats and instrumental verses after doing it, and will basically cut out a minute and half from it.
I get too attached to long outros, but less is more sometimes.
I only have Nero wave editor for that, so I do it by eye and by ear. It's a bit hit and miss but I don't want to be totally in the computer. I know the BR-800 is digital but it still feels like an old school porta studio.
Thanks for the attention and all your efforts.
THE HONEYMOON FLOPS
My heartbeat stops
My jawbone drops
My heartbeat stops
My jawbone drops
My heartbeat stops
My jawbone drops
Great lyrics and phrasing! ?
I like the song a lot. It thought it was really good.
I like the vocal experiments that you did. I caught some pitchiness in the vocals here and there.
ORIGINAL MIX
I wish the guitars had a bit more bite to them. They're not quite present enough in the mix.
The snare was a bit thin and slappy.
The low end was a bit weak.
"SPEED MIX"
Much fuller louder mix
Snare and kick are much improved. The attack of the kick is a bit distracting. But it sounds good.
Low end is at a perfect level IMO.
I'd like the vocals to be down the center during the verses and panned during the chorus.
Not a huge fan of the stereo delay on the lead guitar. The tone on it was nice tho.
Still think the rhythm guitars need some bite.
CLEAN VOCAL CHAIN MIX
I think I like the character of the vocal distortion more than the "clean" version believe it or not.
Revisited this one nine months later and learnt a lot in working with the Boss BR-800, so I'm interested in your thoughts on the update.
I've learnt how to punch in and out mistakes. I've learnt how to copy and paste small parts from other sections of virtual tracks to fix glitches. The Boss guitar to bass emulation has a habit of adding ghost notes here and there. Fixed all those then realised the tone was too distorted anyway so redid the bass, using GR-55 bass emulation which is more reliable.
Removed the distorted rhythm guitar, and added two cleaner ones panned left and right.
Redid the solos, and added harmony run-out melodies.
Learnt how to edit tracks in the Boss, i.e. move whole sections to eliminate over done repeats, and tighten it up. It's still 5 minutes long but I did remove 90 seconds of verse instrumentals between sung verses. Previously, I was doing that manually in the computer. Not with a daw, just with Nero WaveEditor. Sections were moved around manually, with trial and error to get them to line up, and they didn't always. Doing it in the Boss using the measures, means parts are moved and placed seamlessly as long as you use the same measure numbers. For example, grabbing sung verse at 16/01 and moving it to instrumental verse at 08/01 places it seamlessly with no blip or jump, and tightens up the song.
Using the above, I've tried to eliminate out of tune backing vox by pulling better takes from earlier or later. No new vocals recorded, just tweaked what was already there.
Replaced the one pattern drum beat with a programmed one with ins, verses, fills etc. Realised that the Boss defaults to a "hard" drumbeat no matter what pattern you choose, but you can switch to other more natural styles within the same pattern.
Still some things to do. Harmony solos come in too hot so I need to tweak them. Vocals might still be too distorted. Levels of lead guitars could be looked at. Overall mastering volume and tone? Other mixing pointers? Thanks all.
The initial listen I’d say the Vocals are way to crowded and stacked - and they aren’t in time at places - the guitars are better - but there is some kind phase thing happening - better job with the Drums!
I like this song, fun hook and great lyrics. It kind of has a Brinsley Schwartz vibe or Hollies, something from that area, with a little 80s pop as well. All lovely. I think you're missing an opportunity to build the song. You have what sound like 5 voices in the first verse... you could start with a solo voice, add one harmony in the chorus, add another in verse 2, etc. I really like all the vocal parts, but IMO you should reveal each one like another card in a long magic trick. Along the same lines you could add one more instrument for verse 2, an organ taking the place of guitars or something, just to give my ears something new for a few seconds. Perhaps a break down where it's just vocals and drums a little later. This is a really solid song, it deserves a little more invitational (?) feel to a listener like me who loves all of the cliches I just mentioned :). You say you have a tendency to "overload", but that super creativity can easily be tweaked into a superpower.
Thanks. Yes, not being a strong vocalist I fall back on double tracked and over-dubbed vocals all the time. It's the only way I can get my weak voice strong enough. The main part is probably 5 combined, all singing the whole song so definitely a bit of timing issues here and there. Usually one centred vocal, two panned slightly doing the same, then two panned wider either sung an octave down or with an effect from the Boss BR-800 lowering the vocal. Got that from this excellent Youtube video. HOW TO RECORD THE BEST VOCAL DOUBLES. Then there is an occasional doubled backing vocal, usually saying the last word of a line, an octave up. I know some of them don't always line up.
With the guitar phasing, do you mean all the way through the song or at certain parts? I noticed a bit during the instrumental run-out at the end where I've overdubbed a few melody lines and some of them clash, so I am working on that. Cheers, Papanate.
Cheers, Deylight. Very good suggestions.
I'd heard of Brinsley Schwartz but couldn't name one song by them. Thought they were a reggae band! Now I see that it is Nick Lowe and I've always loved his songwriting. Classic stuff, so I will gladly accept that generous comparison.
You are spot on with your suggestion of building the song. If I was starting from scratch I would definitely aim for that. With the BR-800 you only have 6 tracks before you need to bounce them. So the main vocal got combined and locked really. Thank you for saying it's a solid song, that's so good to hear. Yes it could only get improved with varying the dynamics here and there. I was already in the process of dropping the backing vocals for the first verse and chorus, so that should help, but the main vocal will still be the stack. I will look at the final verse again and may well drop the steady rhythm track and revert to just acoustic, strings and bass, something like that, then come back in full for the final chorus. That should be fairly easy to do. Great pointers from you, cheers.
Listening on ear buds and some of the lyrics were a little hard to make out, probably from the vocals not lining up in places. Could have been some masking, hard to tell with ear buds. Good song, keep working on it.
