Halion
I need some help. Today I got my new preamp (DMP3) and headphone amp (ART HeadAmp V) in the mail. Great service from Thomann!
Now I thought I had it figured out but turns out I don't. First here's a list of my gear and how it's currently routed:
Mic balanced XLR out -> balanced XLR preamp input
balanced XLR preamp output -> terratec EWX 24/96 unbalanced cinch input (I'm currently using a home-made XLR to cinch cable with the hot and cold wired together. This works fine).
terratec cinch output -> edirol MA-10A monitors cinch input. These monitors have one headphone output aswell, which I've used until now.
With this setup (without the new gear) I have two problems:
1) Only one headphone out, not enough.
2) Since a mono source will only be using the left channel hardware monitoring only outputs that source to the right output, so for instance the singer will only hear his/her voice in his left ear. Software monitoring would fix this but is not latency free.
I got the headamp to be able to connect multiple headphones and to fix the left ear only problem. However, how and where in my chain do I connect it? It has 1/4" jack inputs, cinch inputs and 1/4" inserts on each channel. Basicly my problem now is that I only have 2 outputs from my soundcard, going either to the headamp or to the speaker.
Still with me? I could make a small switch box that will switch the output signal to either the headphones or the monitors, but I'd rather do it without having to build something. Any ideas?
Or maybe an insert, not sure how those are set up.
