Kevin Deschwazi
I've been happily using cubase SE with a Delta 1010LT for a while now and all of a sudden I cannot record into Cubase.
I go mic-> preamp-> soundcard, the gain meter on the pre is showing a signal as is the meter for the relevant input in the delta control panel, so I know that a signal is going into the card.
So I assign the input which is connected to the preamp to a track in Cubase, double check that the input is activated and nothing. No signal.
Playing back is no problem so there's no issue with the outputs.
It's probably something simple but I've had enough of staring at menus and settings and I'd like to avoid M Audio tech assistance.
So any suggestions?
Thanks alot
So any suggestions?
Thanks alot
