		seankerns
Member
Over the last month or so, I picked up a Fostex E16 deck with a 4050 remote, a 4030 sync, and a 4035 controller. I also got the 8785 interface between the 4030 and my Tascam MS-16, as well as the ribbon cables to hook it all up.
I did that mostly to facilitate syncing the Fostex and Tascam, to transfer a set of tapes which were recorded on that setup, both striped with SMPTE.
In hooking the 4030 to the Tascam, I found that even without a tape on the E16, and therefore no timecode, pressing play on the 4035 controller starts play on the Tascam.
Since I've never yet found a remote for the Tascam, I thought it might be cool if I could use the 4035 as a remote for the MS-16.
But none of the other transport buttons work. I can play, but not FFWD, RWD, or stop.
I have the manuals, two of them, for the 4030 and 4035, but they don't get much into controlling other brands of machines. Their decks are plugin compatible. The only controls on the back of the 4030 are for damping, to fine tune locate points apparently, and dip switches, which from what I can find in the manual, are only meant to accommodate fine tuning interaction between newer and older Fostex machines.
Anyway, I figured maybe someone here has done something like this, so it was worth a shot. I don't want to stripe SMPTE to the tape on the Tascam. Most of them are other people's tapes, and I'm just playing them into Pro Tools to transfer. I'm not doing any recording on any of these machines.
Thanks!
Thanks!
