You are correct. They do cost more. I only read the data sheet when I made that call. The noise on all these devices is really not a factor as it is so very low you could not hear it's effect. The bandwith on both these devices is way more than needed for audio work as well. I am guessing that you probably couldn't hear the difference between these two ICs. Keep in mind these devices are used for other gear that may require extremely low noise and very wide bandwidth. Even if you were to record at 196k BW, these devices would have room to spare and then some.
The 2228 device does have a lower noise spec and wider bandwidth which would probably not provide improved performance in the tiny audio spectrum over the 2134. I'm not entirely sure about slew rate. I believe it is a measure of how much amplitude the output can change in one micro second which relates to accuracy. Larger values I suspect mean greater accuracy at high gain values. At 0 dB, the voltage should be about 800 mVpp if you were to look at it on the scope. For audio, you would not be pushing the output 20 v or 10 v. Maybe a volt tops. If your max freq is 20 kHz then thats 50 uS. You just won't be pushing the chip to the slew limit. It is a measure as to how dynamic a chip is, low values mean a dull, lifeless, compressive, less accurate chip. Maybe after 10v/us or some higher value, this number no longer matters for audio applications but below that you can certainly begin to hear this difference.
Another reason the 2228 might cost more too is that it uses less idle current so it would be great for conserving batteries on battery powered gadgets.
Lower noise, greater BW and less power consumption probably account for it's increased cost. Being that the 2134 is already fit for the job, having more of a good thing just won't provide any more sonic return for your money. That's my guess. The best test is an A/B test. Try the 2134 and then try the 2228 and record the results. There could well be a sonic difference between the two. The spec's state they are both contenders. I've been sticking with the 2134s but others on other newsgroups say they can hear differences among the better op amp devices.
