Chewie
I want to record two guitars, bass, drums and vocals at once but I want each to go to a new track.
I'm using Cool Edit.
What hardware would I require?
Bulls Hit said:Y
If you need more than 8 inputs, you can stack a 2nd 1010LT in alongside the first.
Chewie said:I see the 1010LT has two inputs I could use with the mics bu the others would need a mixer like you said. Now how do I use a mixer to get mics into the 1010LT? I mean as six sperate mic channels?
Chewie said:I've been looking on the website and the don't talk about this. Can you explain? And is this sort of this also possible between one 1010LT and one OMNI studio?
Bulls Hit said:Your mics go into mixer channels 1 -6 and you output from those channels, using either direct outs or inserts, or the main/aux busses of the mixer, into the inputs of the soundcard.
Chewie said:Is it possible to have a mixer with a s/pdif out and then input that to the sound card but with the program recognising the separate channels?
Chewie said:To be honest I don't know what all those terms mean but are you sure that I can get 6 separate preamped outs from the mixer?
Also what exactly are busses. Especially when sound cards talking about having more channels by bussing.
Bulls Hit said:However the MG mixers also have channel inserts that let you output directly from the channel strip, and bypassing the stereo & group buses. These inserts are kind of like a taxi cab straight into your computer
