nessbass
Massive, I've read quite a lot of posts from you in which you recommend to record at -18dBFS in order to not overload the preamps. And I know I already asked you this following question before, but I can't remember the answer or where we had that discussion, so here goes again:
What would be the problem in using the right gains in a preamp that puts out +4dBu "studio level", but running the adc/soundcard at "consumer level", i.e. -10dBV in order to not overload the pre but at the same time get healthy levels into the computer so that more (around 2, that is) bits are stored on disk? Okay, the problem will rear its head in mixing, when you'll have to turn the tracks down to prevent the mixbus from overloading. But I'd rather go safe and record the highest resolution possible even if I have to turn the tracks down eventually (and lose the resolution in the process). But what if not? Then I'd have wasted "good bits", wouldn't I? Or am I just going crazy?
Regardless, there's nothing quite like the look on your clients' faces when you tell them that their tracks are too hot, so you're going to take the square root!
