muttley600
Banned
Yes you can use that one. A little more detail about truss rod installation if your going with yours.
First you have to be sure that its solid. Any weak joins and it'll come apart and its a pig of a job to put right once its installed. Can be done but it aint easy.
The rod you've made looks liks a standard Gibson rod. When you cut the channel the truss rod function improves if it sits in the neck at an angle, higher near the nut and lower at the heel (not crucial). You do need the rod to be a few mm's deeper in the centre of the neck. You can do this with shims glued into the channel or by cutting the slot with a curved jig. Details if required!!??
You'll also need to make a Filler or shim to fill the groove when the rod is installed. This will echo the curve I described above and hold the rod in place . You can use any timber for this. I use Spruce as its light and stiff and I have lots of off cuts lying about
The truss rod does need to be wrapped in something to stop any possibility that it will rattle. I Roll mine in cloth tape. Anything will do the job as long as its a sug/ tight fit. Teflon is used these days by the "Big Boys" because they slop glue about when they glue up the fingerboard and truss rod shim and any squeeze out will not set on the rod or more imoportant the thread at the top. It also makes them easier to remove if required. You won't need to remove yours if you do it right
It doesn't matter that your rod is not straight its more important that it fits the groove you cut which has a dip in the centre in any case.
You can use a bench or pin router to cut the channel but you'll need to think about how to introduce a little curve to the depth of the cut. I have a number of jigs to do just that. It only needs to be a few mm's.
If you use a T or square bar you only need to Epoxy the whole bar into a snug fitting groove. I've built many necks with a Square bar as reinforcement and not had any of them provide problems over the years. As you've made the truss rod I would fit it anyhow it's not that hard. Like anything in life it just requires a bit of careful thought and execution.
Hope this is clear. It's late here and I'm getting tired. If your not sure of anything just holla!!
