Massive Master
www.massivemastering.com
Just adding to dgatwood: True, the converters will (hopefully) *clip* before the preamp. But a CLIP is a FAILURE of the circuit -- It's not like it's "perfect, perfect, perfect, CLIP!"Please forgive my ignorance but aren’t converters going to clip way before the mic pre anyway? I don’t understand why we need to know anything other than instantaneous peak levels in the DAW when there isn’t any danger of the mic pre clipping before the next device in the path?
Or is that just an incorrect assumption based on the behaviour of the gear that I use? My pres barely break a sweat getting even relatively soft sources into the DAW at a good level.
I thought I had a handle on this stuff, obviously not.![]()
It's "Perfect, a little distorted, spectrally questionable, dynamically compromised, noisy, grainy, heavily distorted, CLIP!"
As far as the accuracy of the meters, I can't say. But as far as recording without VU meters, I can -- I also record without VU meters commonly. But I know better. I know where my converters are calibrated, I know what the preamp is doing. A lot of "less seasoned" recordists do not. I've seen so many manuals - some from reputable companies - that say "record the signal as hot as possible without clipping" - when that's SUCH a bad idea that I can't even start.
But like anything else, let your own ears decide. Use a splitter and record the same signals simultaneously. One peaking as hot as possible (without clipping) and one peaking at around -14 or -12dBFS. Lay down a few tracks.
Put a rough mix together using the same levels - Whether you have to bring the faders down to -10 or lower to stop it from clipping on the "hot" mix or whatever.
Put a limiter on the "hot" mix and push it to (wherever it wants to be).
Put a limiter on the "normal" mix and do the same.
Which mix sounds "bigger" and more dynamic? Less noisy? Which mix has more clarity and "openness?" Which is less fatiguing over time?
Which mix can be pushed louder before it falls apart?
I have yet to find anyone - ANYONE - that says the "hot" tracked mix sounds better by any stretch. Even with very high quality gear that has much more usable headroom.
I also have yet to find a preamp that will complain about "not being pushed hard enough..."
