RideTheCrash
Member
Alright, so I'm not sure what the heck was changed back when my dad had originally given me a hand, but I think he was looking at the mic level one. As it currently stands, track 2 is half the volume of the rest of the channels, and channel 1 is probably still lower than channel 2.
So with the pad being mentioned, I think the manual kind of makes sense now. These are my options.
1. Mic Level (+30dB gain)
1A. Mic Level (attenuates +30dB by 11dB (i.e. +19dB gain))
2. Line Level (+14dBu peak (+4 mode))
2A. Line Level (Changes Line Level to +3dBu peak (+4 mode))
Then it says:
"NOTE: Illustrations 1a and 2a show a variation on the mic level setting and the line level setting, respectively. If you find that your signal is too hot using the +4dBu selection in the Delta Control Panel's "Variable Signal Level" section of the Hardware Settings page, then try these alternate settings."
Well my equipment is running at -10 I guess. I just want the volumes of channel 1 and 2 the same as channel 3, and want to get it right the first time so I don't have to keep opening up my computer.
Then it says:
