Myriad_Rocker
Why can't I adjust the volume of my monitors through the Delta 1010 Control Panel. When playing an MP3, I can adjust the volume from WinAmp...but not the control panel.
Jim Y said:Lemon Tree, in this case, the "monitor mixer" is part of the m-audio drivers control panel. It allows you to set up a mix of any of the ins and outs and route it to a choice of output. The idea is to provide "zero latency monitoring". It isn't quite zero though, because the analog converters on the card delay by a millisecond or so. The Mixing is performed in the cards audio controller chip ( IC-Ensemble Envy24), is entirely digital and doesn't take any cpu power from the host machine.
This doesn't matter to the program providing the audio, so long as its set to use one of the M-audio cards output channels, and that's enabled in the monitor mixer - and it can even be one not directly feeding anything else. The Mixer re-routes it.
Additionally, you can record the monitor mix as the driver has a Monitor mix record channel - useful to captire the output of one program into another if either don't support re-wire.
