Dolemite
I finally got tired of loud-ass case and CPU fans...
I replaced the case fans with PC Power & Cooling Silencers. You can get them now for $9 each with free shipping, which is pretty pricey as fans go, but these babies are the quietest 80mm fans I've heard - much better even than Panaflo's, though I don't think they move quite as much air.
I replaced the CPU fan on my Global Win FOP38 with a Nidec Gamma 28. I actually replaced the ridiculously loud stock Delta fan just minutes after I installed the FOP38 with a quieter 60mm fan I had laying around...then about 2 weeks ago I decided to see if my old whisper-quiet Gamma 28 would move enough air to cool my T-Bird 1.2 overclocked to 1.33 GHz. Sure enough, its actually a bit cooler with the Gamma 28 than with the slower 60mm fan. The Gamma 28 is what is caller a "squirrel cage" fan or "biscuit blower." It doesn't produce as much CFMs as a typical 60mm CPU fan but it is very directional, focusing airflow in a small area. So I went to work with some zip ties and attached the Gamma so it was blowing directly on the area of the heatsink right over the CPU core. You can get these fans at Radio Shack for $17.99, which is way too much to pay but not so bad if you have a local Radio Shack store so you can avoid shipping costs. They're also available at Overclockwarehouse.com for $9.
Anyway...now my system is just as cool and MUCH quieter. Before, the noise would start to bother me instantly if I didn't have any music or background noise, but now I can just sit here in relative silence. I also record in the same room with my DAW, so now I know I won't be picking up fan noise on my tracks.
