C
c9-2001
hows this preamp? i've never used it or hear it, but i had a friend buy one.. he wants me to set it up on tuesday.. is it a clean pre? good enough to use a tlm103 with?
The 107 does have a tube...er...toob. The 207 appears to be just a re-packaged 107 with limiters and insert jacks. You can read about it at the Aphex site.c9-2001 said:it shouldn't have tubesence b/c it actually has tubes in it where the 107 doesn't...
he bought the 207 on ebay for a good price($250)... the limiter in it i hear works well.. i'll probably tell him to get a clean compressor to go with it or track with nuendo using compression in the signal chain(i love that featureFlatpicker said:The 107 does have a tube...er...toob. The 207 appears to be just a re-packaged 107 with limiters and insert jacks. You can read about it at the Aphex site.
For the price of the 207, you could buy a used 107, an RNC, and have money left over or just get the Focusrite TwinTrak Pro with two full-blown compressors and a few other tricks (that would be my choice...).
)Once in a while, if you look really often at eBay and on-line classifieds, you'll find one for $125 plus shipping. And keep in mind it's not money thrown away if you don't like it (I'm betting that you will, BTW), because you can probably sell it for every cent you have in it.c9-2001 said:anyone with a used RNC????
i doubt my cousin wants to spend 175-199 on the RNC right now...
the 207 is actually balanced..dwillis45 said:Try using the insert jack on the back of the 207. The jack is an unbalanced TRS plug and accepts a conventional Y cable.
Should be fine. Just keep it away from wall-warts and AC Line cords.c9-2001 said:... the cable from the pre and comp.. should be about 2-3 feet max...
