microphone bias and reasons
A few mewsings that entered my head. When you listen to a ribbon mic - the circuit is very simple. A thin bit of foil, almost a short circuit - a transformer (more wire and an air gap) and that is it. You can get a bit of foil, run it through a home made corrugator (made from mechano gears maybe) and clamp it under the terminals. You can have the corrugations very zig zag or pull them out a bit. All that changes is the tone - changes to the frequency response. Nothing really else you can do. Maybe the foil itself could be swapped, but all that happens is the frequency response changes again.
Dynamic mics are more complex. A coil of wire that is bonded to a diaphragm. Far more interaction - and the diameter of the coil, the wire cross section, how the wire escapes the area, the diaphragm size, material, weight, plus maybe a transformer. The end result is a frequency response plot - but so many factors now have an impact. how quickly the coil moves in the gap from stationary to full speed then how quickly it slows down - down to the diaphragm and how it is physically suspended.
Proper condensers (cannot say capacitors) are more like the ribbon. A circle of conductive material insulated from what holds it taut. usually with a nut and bolt and a wire in the middle. Then a gap, then a back plate, or another film of the conductive material, this time attached to the metal structure at the edges.
Then some electronics to convert the change in capacitance to changes in a voltage.
Of course, some electronics designs will be sonically superior, but the killer is how well the diaphragm follows the audio exciting it. In the Neumann videos you see some amazingly skilled humans doing this. The important features seem to be the tension in the membrane, and the nut and bolt connection in the centre.
I can see that the dynamic has the most scope for sound differences - so many individual processes where sound can be impacted. The condenser mic elements are really simple. The difficulty is making them - I found this Russian video
youtube link
German and Russian factories drill hundreds of holes by hand - in China, it's a CNC machine. video here That indicates consistent quality but far cheaper.
I suppose the point I am trying to make is that the electronics differences make far less difference to the sound, than the capsules do? Rode, Neumann, Soyuz are labour intensive processes - so an extra tweak on the nut and bolt will change the tone. If the mechanics are done right, you get a nice product. The cheap condensers (screening out the genuinely awful ones) only have to get the capsule right to be sought after. A nice capsule in a body made from old plumbing pipes will sound great.
Nobody ever takes a diaphragm out of an expensive mic and does a capsule by capsule comparison - that would be crazy, but it really is that one component that is the critical one. Wouldn't it be interesting to have a real shootout with the capsules only? Is it the Neumann capsule that really matters? I know some folk change resistors and capacitors in the preamps to improve them - but are these electronic improvements really valid - or do they just tweak the frequency response in the same way EQ would?
Yes Rob, it seems capsules are king and good deal of time and effort is expended on trying to copy the old designs.
I am wondering why you "can't say capacitor"? I reckon you are at least 10yrs younger than I and yet when I did day release electronics at 17 the term "condenser" had been replaced with capacitor in technical parlance. And! To be consistent you should use the term "condenessness"! and not "capacitance".
I say leave condensers to Jimmy Watt!
Many years ago, Rode did a video showing the machinery they use to manufacture their microphones, including CNC machines for capsules and bodies and their tensioning system for diaphragms. One point that Freedman tries to make is that once you control the process, you get consistency and reproducibility. It's that way in most manufacturing systems. Consistent incoming materials, consistent processing, assembly and measurement results in a consistent output.
I think one of the reasons that things like guitars or violins don't respond perfectly to this system is that wood isn't necessarily a consistent material. Even though you might specify spruce or mahogany for an instrument, trees vary, how it's cut from the log varies. Wood will gain or lose moisture which causes it to swell, shrink or even crack. That can change how the instrument responds.
Some of my guitars seem to change tuning more with the weather than others. They are reacting to the change in environment. A month ago, I tuned up my guitar around 4:00, took it to the outside pavilion where we were playing, and when I started 90 minutes later, it was about 1/2 step out!
The guitar company can't control something like that, until they use different material (hence the graphite, carbon fiber, fiberglass and metal guitars). I played a Rainsong guitar a few years back, and one comment the owner said is that was great is that it sounds and plays the same whether it's 40° or 95° on the stage.
There is a parallel here Rich with firearms, rifles specifically. Historically stocks were made from a chunk of a nice wood, walnut as a rule here which could change the recoil characteristics with the weather with an impact on accuracy. This was combated by the development of "glass bedding" whereby the action was set in GF, car body filler essentially. Some stocks were made of laminates of timbers using epoxies and are very stable and inert. They are also beautifully patterned when the shape is cut from the laminated block. Never seen a laminated Tele neck?
Of course, many stocks are now plastics. Super stable, strong and weather proof but ugly as *&^K!
Terms like 'Mahogany' and 'Rosewood' are a matter of interpretation, and vary around the world.
I always think of every change we hear are just different EQ tweaks, in general the "EQ", the Frequencys are tweaked or different due to X=variable.
Someone might prefer the AKG XLII its brighter! and someone else likes the 414 XLS is flatter...only the Original one with crusty spittle capsules are warm!!
I don't doubt they sound different and similar as its a design of the same thing kind of. as if the circuit design has some Frequencys boosted or nulled?
Painting Analogy is Mona Lisa, the painting, and if someone copy's it, its not exact but it should resemble the Mona Lisa and isn't surprising.
if someone takes freedom to paint a beard on her, well then that might get a different response. So I assume a Cloners 87i would sound similar to a U87i as its a copy and they can do their work well. (or its a scam marketing thing being a fake and in Name only)
I don't think individual components make much difference in comparison to changing a transistor in a U87 from the current Fairchild to a original Texas Instruments transistor...but I don't know? the DIY- AKG P420 is proven that one capacitor change is a pretty large noticeable sound change....
if a person likes it better or worse is subjective. no accounting for taste... is just using EQ the same as doing all that soldering and part swapping?
but then one could wonder if I use EQ and the $150 RODE can be matched to a $4000 microphone why spend the cash?
Most people wouldn't - there are other thing in a microphone beside frequency response that make them valuable - Slate has the Virtual Microphone System that for the cost
of $400 you can emulate a hundred microphones or make a new one - why doesn't everyone get that? For the Price of one U87AI you can get 10 MA-1As and have a huge mic locker -
I don't know that the clones of U87s are exact or not - I've compared some and I actually like the Clones better - but that doesn't discount the U87 - because back in the day no one came close - so if you wanted that sound you would get that mic - interestingly the U47s I've tried are all good but vary in sound somewhat . Blackbird Studios U47s sound superb - Oceans Way U47s sounded good but not as good as Blackbirds - but Alan Sides thought they did - so that tells us that Alan SIdes had an ear for the mics he liked - bTW He bought and sold over 400 of them and always kept the ones he liked best.
Which is to say the microphone landscape is what we make of it - we go with what we can afford and like - so in my case I would get the Rode and tweak it before I bought the U87.
I use the ml2 and really like it.
Mostly use it as a vintage sm57 and rb121 mix. But also solo it sounds great on a cab.
bias popped in my mind today,
floating through gear forums and the web..... FET 47.....without hearing it or seeing it...."its a kick drum mic" assumed.
Neumanns 47 FET became some Kick Drum mic, and it seems now the bias is ....47 + FET. = kick drum mic.... forever to be.
FET circuits are "field effect transistors", some have transformers and some don't. Seems in general if its FET + 47 = Kick Drum mic.
Did Bias really start back when Neumanns failed 47FET couldn't convince the Studios it was better than their 47Tube mics for Vocals and cabs.?
Oooh - that never occurred to me - German marketing before we even knew marketing was a thing. As the capsule design is established - as is the preamp circuitry - how on earth has it got it's now current reputation as a wonderful non-vocal mic? The 1970s initial sales must have scared them.
I'm half joking, I wasn't really around when it happened ...
I was looking at trying a 47 FET seems all the reviews were kick drums, and then compared to the Neumann 47FFET.
Who made the 47 FET the kick drum mic then? some big name album or producer? The big studios who kept their U47 tubes on vocals?
