X
xstatic
cavedog101 said:You had a LOT of ear training to be able to appreciate the difference. This is something that 90% of the folks on here will not have. Not meant as a slight....on the contrary, its what we all need and as Harvey said originally..'a lot of people on here havent learned to use the gear they have'.... There is no magic bullet. There is hour upon hour upon hour of simply hearing and trying different things and searching....Its the only college that really teaches.....
I personally will not take that as a slight, but more as a compliment. There is some truth to that as well. There was definately a time in my career where I would not notice as much of a difference. In hindsight though, there was a lot of gear over the years I wish I had not bought. I wish I had just skipped buying a few cheaper pieces and saved and got something better from the get go. The way I look at it now, is that if you do buy something nicer now instead, you may not be able to fully take advantage of it quite yet. However, it will be there and grow with you as you do. High end equipment holds its resale much much better than cheap stuff, and it can stay with you for much longer (making its money back through its use. I also believe that getting some of that stuff actually helps to train you faster as well since your limitation at that becomes your own experience and not the gear that you are using. In the end, I can not see regretting getting some good solid pre's, as long as you have the means to do it.
