Stand on metal to ground myself instead of a hum eliminator?
  • Thread starter Thread starter Bargarcs
I happen to have a bass, amp and USB mic to hand. The bass peaks to -10ish and the noise eventually drops to a (reasonably?) acceptable -60dBFS ish. Were I to move around the room with the bass I reckon I could better that by 10dB? But I would say, in a song mix that S/N ratio is good enough?
Geeez! That's nasty! I would not be at all surprised if that is due to the overhead lines. I suspect there is also some electro-staic pickup as well judging by the higher harmonics. Do you know the line voltage?
But WHERE is the chuffin' guitar? The figures mean Jack unless we can refer them to "normal" playing levels.
I shall see if I can post an example.
Line voltage should just be regular 120 volt, in a basement of a residential home built in 2010, and basement wasn't finished until 2015. I could post an audio of moving the guitar around so you can hear how the noise changes based on the orientation and location of the guitar if that helps?
Ah, when you mentioned "overhead cables" I was thinking 132kV pylons? Yes, run the guitar facing N S E and W.
I don't know how far they can cause interference or noise so here's a photo taken from the window so you can see how far those power lines are. At that distance, can they still be the source of my issue?
Almost certainly not. The thing with interference is that it drops of VERY quickly with distance due to the inverse square law. double the distance and the interference drops to ¼! double again and it's a 1/16 of what it was. If the quality and volume of the hum changes as you spin through 360 degrees, then you can track it down reasonably simply. move to one side of the room and do the spin with the guitar on a strap. There should be two peaks. one will be at 90 degrees to the neck in front and the same behind. find the maximum interference direction, and the source is on that bearing. Then go as far as you can away from that position and repeat. The direction should be different. but the source is on the new bearing - where the two cross is the source. This will fail if the interference is being propagated by your house wiring. However, it can help you find things like wall wart type power supplies misbehaving, or individual bits of kit if they are causing it.
So assuming it's not the power lines because of the distance, to rule out any of the audio components. I will unplug from the wall, everything except for the guitar and the mixer, and put headphones on (connected to the mixer) to see if the hum noise is there. If the noise is still there without any change, then it's coming from the house wiring? I tend to think that's what's going to happen. How do you defeat house wiring noise?
Here's another discussion on the topic:
Notably:
If your issue is purely defined by what direction your guitar is facing then it is an electromagnetic field (EMF) issue.
Single coil pickups, by their design, convert electro-magnetic energy into electrical energy. Those little, subtle, wobbles of your strings, wibbling about in the field of your tiny little magnets. When we had real tubes in our computer monitors, it was pretty bad, and of course, close. It got better when we swapped to flat screens, but got worse when switch mode power supplies became everywhere. I have found these the worst generators of noise, some crazily so. Often the noise they generate propogates through your house/studio mains power wiring, spreading out the origin point over a wider area.
It is well worth it to pull everything you can, that is not essential. So strip down what you have to a minimum. Unplug everything bar the computer, monitor, interface. Dont even use amps and speakers, but headphones. Absolute minimum gear, and see how noisy that is. Add your kit, one by one and see if you can identify one specific item. For me, in my video studio, it was the 4 port network hub. One other thing caused grief. My Adam speakers. Plugging in these caused some kind of grounding issue, and these now have their audio going through a transformer isolator. In my home studio, these monitors are silent. I neverr found the cause, but the isolator cured the noise, presumably coming from something else.
Plugging in a Les Paul produces just guitar. My Strat just hates my studio. At the theatre I look after, I sometimes see single coil players struggling with feedback and weird whistles and noise. I quietly walk up to the rack, stage left, and turn off the hearing loop, and the guitar behaves. Not every guitar with single coil pickups, not the same make, or pickup brand. Has the guitar got shielded pickup cavities, or screened cable between pickup and switchery? No idea. Just happens.
I have pylons close to my house like that.
They have never given a problem.
Just unplug or switch things off. No current - no transmission.
Yes, bang off the main breaker(s) and run laptop on battery. The OP's noise has two features that tell a story?
Firstly the main (huge!) peak at 60Hz. That can only come from direct mains 'injection' almost certainly 'magnetic' and likely a transformer. Equipment hum will be 120Hz (100Hz EU) because nobody uses half wave rectification these days!
The second observation is the EXTREME DIRTINESS of the rest of the spectrum! That suggests to me a poorly designed or badly shielded Switch Mode PSU. OR! The UMC is noisy. Try a recording with gain at minimum and ideally input shorted. I shall do the same for my KA6 in a mo'.
That was done with the inputs switched to 'Line/insrt' and at minimum gain i.e. the converter noise plus the line preamp residual.
Purty clean innit?
If I walk to the corner of the basement next to the distribution box, I can get hum in any of my guitars. It's a whole bunch of unshielded Romex cables going off in different directions to all parts of the house. One day I found that my pedalboard was making noise. I was just practicing and I had it right in front of my little Princeton Reverb amp. I moved it 5 or 6 feet and everything got quiet again. It must be those big beefy transformers in the PR amp.
Any alternating current flowing through a wire will create some EMI. You either use distance or shielding to minimize it.
Were you playing a Humbucker equipped guitar? I know my single coils that aren’t silent types are susceptible to hum sometimes - but not in my studio - which is Opto Isolated and Balanced power - also do you know how you might go about shielding Romex Cables? I would think that would be a monumental task.
Yeah, it had humbuckers (Sheptone Tributes). If you get close enough, you can get noise. Humbuckers are better, but not perfect.
The trick isn't to shield the Romex although I guess you could run all wiring though conduit (kinda costly, though). You shield the pickups and wiring harness.... and move to the other side of the basement!
Heavy 1" Iron conduit might reduce EMag radiation a bit but I doubt it would make much difference. If the tubes were securely bonded to earth that would kill all electrostatic radiation. Due to that 60Hz spike I am convinced this is due to a transformer somewhere.
But! We still don't have a reference level! Neg 40 is pretty bloody awful if it is ref' -20dBFS but ref -2dBFS not quite so bad. The good news is that 60Hz is well below bottom E and so a steep HPF can be used to clean it up. The rest of the mess, not so much.
So I unplugged everything in the basement, and connected the mixer directly to the wall outlet. Still had the noise..
Rummaging through gear, I found this Samson MDA1 direct box and decided to try it and much to my amazement, the noise is about 80% gone, gone so much so that it's not going to be a problem anymore I don't think. Prior, I was going straight into the mixer's Hi-Z input.
I'm wondering if there's another direct box out there that might work even better?
Do we know the make and model # of the mixer? Some mixers are earth free, my Behringer Xenyx 1202 is one such* The DI box makes the guitar a balanced input. Maybe check the mixer and all the system has a solid connection to mains ground.
*But does not have any high Z inputs so not suitable for passive guitar.
It's an Allen & Heath ZED10FX
Nice! My son has the exact same mixer and yes, it does have high Z input options, are you using one? He has no problems with a passive Telecaster. You need to check your kit is earthed I think.
Well here's a new recording using the Samson direct box. The hum noise is better, but not gone. It seems like there's a lot more hiss noise than before, but maybe my imagination. For the recording I posted the other day with no direct box, yes, I was using the hi-z input on the mixer. For this recording, no, I'm in channel 2 with XLR from the direct box.
0-8 seconds, hands on strings
8-17 seconds, hands off strings
18-41 seconds, playing with track
41-54 seconds, playing without track
But still no guitar! Therefore we do not have a reference level for the hum. BTW are you using the mixer as the interface? That is making a USB recording? If so can I suggest you have a very early, 16 bit zed10? We do.
