bouldersoundguy
Maybe tilt the amp up so you're hearing the speaker on axis. The highs drop off rapidly as the angle increases. What the mic hears on axis might be quite different from what you're hearing at 45⁰.
I gotta try that myself.Maybe tilt the amp up so you're hearing the speaker on axis.
Honestly, that never occurred to me. I have a very small space. My amp ( a 40W Fender w/1X12) is way overkill for what I need). My recordings are always too shrill, with absolutely no bottom. I don't turn it up more than 2, not even enough to heat the tubes.I gotta try that myself.![]()
I've done that on stage, never at home.
Same here 'cept I've also done it at home. Place a single SM57 midway between the cone and edge of either right or left speaker of the amp and record it. It's not exactly rocket science to capture what the mic is actually *hearing/transmitting* to your DAW or standalone recorder provided it that that your recorder is recording a *clean* signal to an assigned channel completely free of *presets*.I gotta try that myself.![]()
I'll tell you a secret. SHHHH!a single SM57
A tilted amp has other benefits.I gotta try that myself.![]()
i tilt my amps all the time.Honestly, that never occurred to me. I have a very small space. My amp ( a 40W Fender w/1X12) is way overkill for what I need). My recordings are always too shrill, with absolutely no bottom. I don't turn it up more than 2, not even enough to heat the tubes.
I have a smaller Champ 20 that I might try, but the suggestion of a 45 degree tilt is great. Thanks
Or, maybe I need to build an isolation room, and let that Fender scream!
This is just a disaster of a thread. It’s like going down nto an ant hill. More twists and turns than a rabbit hole.
Same. Unfortunately, I don' get enough volume to rattle the walls. Unless, I fire up the B3My studio has concrete floors with a few rugs.
MATGA ?At least this thread is finally fun again.
MATGA. ( make all threads great again) ;-)
I discovered years ago that my dad's old banjo that I had hung on wall within my room was problematic. I removed the strings. End of problem. Didn't even need to search the internet for a solution.I figure something in the room is vibrating when the amp is on concrete.
Thanks Dave for the info! I want to change out my Twins speakers with C75 or vintage 30 later down the road.Simplex09, I have been involved in audio electronics for well over 60 years (no! no transistors then) and spent my last few years with a guitar amp company. Mainly in the "lab" running tests.
Now, despite all the claims you read about and see on clickbait YTs, valves ("tubes" are what you get in bog rolls) make only a marginal difference to the sound of an amplifier. It IS a little bit brand and design specific but nothing like the "night and day" revelations you get told.
The "in the room" Over Drive tone of a guitar amp is largely formed in the valve pre amp section. The output stage makes very little difference until (by definition) you are blowing the absolute bollox off it. Most people can't do that with a 5 watts valve amp leave alone 50 watts!
Speakers make the next big difference but even that is totally subjective. There are no really 'bad' guitar speakers (Hmm? Rocket 50?) just WOT I Loike. Some makes are however more reliable than others.
I know this because I have built circuits that can instantly compare ECC83s say in an amp circuit. Nowhere on The Tube will you see such "scientific" tests AFAIK? We also A/B'ed different makes of output transformer...FA sound diff.
Yes, you will read and see claim and counter claim in the magazines and online and in forums but this is an INDUSTRY! They all have to SELL shit!
Here we go again. Build you own cables for f*ck sakes. This is so stupid.So I went out today and bought a brand new Ernie Ball cable because my fender cables were giving me so much static when playing and it was hard to get them to work because it would be cutting in and out when playing.
