People here are very generous with their time and sharing wisdom, but in the end there’s things you need to learn for yourself.
@Simplex09. Heed
@RFR . Members here have joined for basically two reasons: To get help when we need it, and lend advice when asked.
@rob aylestone is right in his post about "people being frustrated". If you boil all the replies to your question, the best advice comes from
@rob aylestone "the old don't run before they can walk".
Start with a guitar and an amp. Play with the EQ and volume knobs on the amp until you get a sound out of the amp you like.
Then, plug in your stomp and dial that in, without mucking about with the amp settings, until you get a sound that you like.
Then, put ONE mic in front of ONE speaker in the cabinet, with the mic positioned up against the grill cloth, in the middle (cone) of the speaker.
THEN, record that.
This splits your problem in half (which is what any good engineer or tech would do). If the amp sounds good to you, but the recording doesn't, then you know the issue is on the recording end.
If it's on the recording end, then repeat the steps above: one step at a time,
If you keep dividing the problem by elements, the skies will clear, the curtains will part and you will achieve the knowledge you seek. (That was the best advice I was ever taught in school).
Work with us, and we will gladly work with you.
