sweetbeats
Reel deep thoughts...
I’ve seen your post…will respond in detail when I have a chance to do so.
Regarding head relap, I have a dremel, can I use one of those furry attachments and do it myself?
Does the tape stuck to the heads, a good indicator that it is rough in that area?
If I get it relapped, does that mean I need to have this unit calibrated - ie. adjust azmuth, use oscilloscope, and use other tools?
Trying to weigh out whether I should just leave it as it is, I do not have the budget to send it off to a professional, trying to do DIY.
I am considering just using an EQ in my DAW to match the left and right frequency response.
My priority is to stop the shedding/damaging of the tape when I use this unit.
Looking at the sync head, I think its worn out rough badly. Shouldn't it be curved, it looks flat and has some sharp edges to it? What do you think?
Also, looking at the heads, do you think these have been relapped before?
I was using the term “rubber renew” generically…referring to your rubber cleaner. You only have one pinch roller. The rubber roller on the takeup side. I usually use water to clean the rubber rollers, Windex if something more is needed. Your rubber rollers are in need of replacement/rebuilding…you can try to use your rubber cleaner in them but it’s only going to do so much.@sweetbeats, what should I use to clean the rubber pinch rollers?
I don't think that blue stuff is rubber renew.
I am listening to what you are saying, it is very good information which I am using partially and will use the others later in the future when my funds can dedicate some portion to get the 52 back to its glory. This info will also be helpful for others who may be in similar situations.
@RFR, that depends, there are some cases in poor countries where used parts are used as long as it is within "safety tollerance" (that's if they follow it)? ie. helmets.
I think this needs de-magnetising due to the roll off in the high frequencies from the Logic frequency response and the units history of use.No I don’t think so. In my experience a machine needing degaussing will have some diminished HF response, and in extreme cases there will be small pops or crackles imparted to the signal printed to tape. I always degauss a machine that’s new to me just because I don’t know when it’s been done, and then every once in awhile for preventative maintenance or if I notice symptoms.
Sure I get that.@sweetbeats, what should I use to clean the rubber pinch rollers?
You keep asking questions, and getting informed answers. You then are disregarding some of those answers and conjecturing your own reasoning. Wait her ask the questions and follow the advice or don’t. Taking time to thoughtfully respond only to have you veer off in a different direction is not a valuable way for any of us to spend time.
There’s already guys who are true professionals who make them. I’d much rather go for one of them than a person who lacks familiarity. Why add more complexity?Does anyone know the exact dimensions and specifications for the Pinch Roller tyre? I can't seem to find the dimensions on the Service Manual. The Part#: 5800347601 based on the exploded diagram.
I presume they are made to be flat and not concave or angled in any way?
I am trying to source someone local to make the tyre if possible.
Thank you.
