No they don't. There is no P101 or P102 on buss b unless it's the place the m buss board (green connects to). In which case, you're quite right but you should be aware that the 8 input pcbs also have connections labelled P101 and P102 on them AT THE BOTTOM OF EACH ONE. Not in the middle where the green board attachesP101 and P102 connect to the long buss PCB that goes across all the mixer PCBs.
Yeah. I see that. I know that. You are the only person in this correspondence that cares anything about the input PCBs right now. I’m not arguing with you about that. I don’t care about that. So let it go.Why can't you see that there are clearly 8 pairs of white connectors at the bottom of all the input pcbs? You do know I have the machine on it's back, right?
Yes. I am right. Because that is exactly what I said in my post, P101 and P102 on the BUSS B PCB connect to the M. BUSS PCB.No they don't. There is no P101 or P102 on buss b unless it's the place the m buss board (green connects to). In which case, you're quite right
That was exactly my point, that we don’t need to worry about them, because they mate with the M. BUSS PCB. Read my post #79. I was walking you through each connector because in an earlier post you got concerned/distracted when you thought I skipped connectors, but I didn’t, they didn’t exist on the PCB we were discussing, so this time I decided to make sure you knew I didn’t skip them, and that we don’t need to worry about them, but then you decided to go far off the trail and start talking about the input PCBs and argue that connectors that clearly exist don’t exist.Then can we stop talking about connectors P101 and P102 on the B buss board (because they don't exist or I've already dealt with them) and move on? Maybe you have a misprinted copy of the manual (or maybe they're all misprinted).
So what? Who cares? You need help right now with the BUSS B PCB. That’s all I’m focused on. That’s where you need help. You can worry about the input PCBs by yourself.So do all the input pcbs.
Uh huh…which is exactly what I told you in post #79:104 was easy. There's only one white four hole connector that matches that description
…let’s move on to P104. This one I believe mates to what is the only white 4-pin plug with the yellow and orange shielded cables…
