G
Greg_L
Banned
Greg,
Thanks & yes please.
I'll render a version with the count int and no drums for you in the next hr - it's at 120bpm.
Got it, thanks Ray.
I've been fucking around with my clusterfuck of a pedalboard. I had shit wherever it would fit, but I put a little more thought into it this time and arranged things in order of usefulness and trying to find a balance between the true bypass and buffered pedals. I've got about 50 feet of cable between my guitar and amp so I need to get it right. So this is what I ended up with....
Before:
After:
The "after" layout is more logical for me.
It goes guitar > Boss SD-1 (buffered) > Tuner (True bypass) > Tube Screamer (buffered) > Boss Flanger (buffered) > Phase 90 (true bypass) > Boss Tremolo (buffered) > Crybaby (true bypass) > amp. The Flashback Delay and MXR EQ are still in the effects loop when applicable. Having the Wah first is most common, but I like to use it left-footed, and it's true bypass with a buffered pedal right before it, so fuck it. It goes last. I've got a buffered pedal to start it all off, and one next to last, so that should be good enough, and the layout works better for me. And believe it or not, it sounds better. Much less noise. That's a win!
My back is still jacked up, so I popped some more vicodin, because it's awesome, and chased it down with the nectar of the gods - jaegermeister. I got another super happy fun buzz going, so I whipped out some tone. I'm not sure if this is good or not.
Les Paul Traditional - Burstbucker 3 bridge pickup
Marshall JVM 410 - OD1 Channel, Green mode
Presence -3
Bass - 6.5
Mid - 4
Treb - 6
Gain - 3
Channel vol - 4
Master vol - 4
Tube Screamer engaged as clean boost - drive @ 0, level @ 2:00, tone @ 12:00
Marshall 1960B 4x12 - Vintage 30 - single SM57, on axis, on grill, just outside dustcap
No EQ or anything in DAW.
Ace of Slop
Lemmy know what you think!
