famous beagle
I've played guitar for 25 years, and in that time, I've played Strats, an Ibanez, a Hagstrom, and an Epi Dot. I had never had an issue with getting a buzz when I wasn't touching the strings.
So I bought my first Tele (on ebay) a few months ago, and it had this problem. It would noticeably buzz when I wasn't touching anything, but the buzz would go away when I touched the strings (or the pickups or metal knobs). Both pickups are single coils.
So I thought, "what the hell?" I looked online and found some people saying things like:
This is normal and is the reason your strings are grounded—to eliminate 120 cycle hum when you touch the strings.
But I thought, "This is silly. I know I've played other people's Teles, and they didn't have this problem." So I did a bit more research and found out that most Teles make their ground connection to the strings via a metal plate on the bottom of the bridge pickup. I didn't understand exactly how this worked; I only knew that my bridge pickup didn't have a metal plate on the bottom of it.
So I soldered a wire from ground (the back of a pot) to the bottom of the bridge, and presto --- buzz is gone.
So ... what the hell gives?
I'd like to understand exactly why this happened. Why was the buzz going away when I was touching the strings.
I know that some people will say "Well, when you touched the strings, you grounded them" But, that's the case, then how? How was I grounded? I was on the second floor of my house in a carpeted room in my shoes.
What the hell is the final word with this? Why are some people saying this noise is normal?
Anyone????
Anyone????
, in fact, all you've done is wired the ground correctly that was not there. My Tele has no ground buzz...just the single-coil noise.
