witzendoz
Senior Member
I am assuming this is a windows machine? what version of windows?
How do I "reload"? Do you mean reinstall or something completely different?Try to reload driver for the firewire device
Yes, I did mention earlier I think, but it's Windows 7 Ultimate 64-bit.I am assuming this is a windows machine? what version of windows?
It's looking more like a firewire device problem in the computer, have you got any other firewire devices you could plug in to try out?
reload, yes I meant reinstall
Sorry I did not remember you said windows.
I am thinking that the best course of action may be to system restore the computer to a time before you loaded the Presonus drivers and initiated the device.
I don't know if you know how to do it but here is a guide anyway. I am using XP here at the moment so it could be slightly different but you should be able to follow.
Go to all programs (under the start menu) > accessories > System tools > System restore.
Select "restore my computer to an earlier time" By clicking on the calendar you should be able to find when you installed the presonus, if not go back to a point you know was before.
Click "next" and follow the instructions.
When it's all finished install the presonus again as if you are installing for the first time as per the instructions.
Alan.
You had it going once, right? And the blue light magically appeared.
When you did the system restore, then reinstalled the firestudio, I take it that this failed to give you a blue light, even once?
Does the firepod have a second firewire slot? Did you try that?
You might also like to go to the presonus site and download latest drivers (you may have done that already).
You might want to try and uninstall the hardware instance of your firepod and force it to reinstall the drivers.
I'm not sure what version of Windows you are using, but under My Computer->Properties->Hardware Tab->Device Manager
Click the '+' next to Sound, Video and Game controllers. Select your firepod instance, right click and select uninstall.
Reboot your pc and it should detect the firepod and begin the driver install.
Good luck...
Your Firestudio should absolutely be listed under Control Panel>Sound. If not, the driver has not been installed correctly somehow.
Try another firewire cable. If it's not being reported as a active audio device then no firewire connection has been established.
Since it worked prior to this, I'm guessing that the drivers are still installed.
This ^^^^^ , also have you checked that the firewire card hasn't been knocked loose? (assuming it's a pci card). It's really too bad you don't have another firewire device to narrow this down to the FS.
The only other thing I can think of is to uninstall everything presonus and install from the original disk. I know sometimes the firmware has to match the driver version.
Bring your firewire cable to a local pc shop and ask them to test it. If it's bad, I'm sure they will have another for you to purchase.
It seems that if you are a new installation instructions, but PRESONUS already installed so you do not need to do this.This work for me, I had to use PRESONUS how the Firebox, and it is FireWire. When I have lost over a FireWire connection to the combustion chamber, I just do.
