1
1tune
I recently purchased a Zoom Live Trak L-20, and trying to record for the first time. I just have a dynamic mic connected to CH 3 to test it out. I have read the “Quick Guide” and the operating manual. The instructions seem straight forward, but something isn’t right.
I have an SD card that has been formatted and tested “ok”. One thing the directions don’t specify is where the “Mode Switch” should be. It was in “Audio Interface” on my first test that didn’t work, so I moved it to “Card Reader”, which is not the correct position as the screen tells you right away. So I moved the switch back to AI.
Anyway, I proceed and create a new project, as this is my first one. It says the Over Dub light should be off for a new project, but I can’t make the light turn on by pressing the OD button. Then it says press “Rec/Play” for the channels you want to record. I press CH 3 Rec/Play (where my mic is), but it does not light. I continue through the process anyway, but no recording takes place.
Does a computer need to be connected to record? The directions don’t say that, as far as I have seen.
Any help would be greatly appreciated.
Thank you.
Thank you.
