muttley600
Banned
The so called "stretching in" is a bit of a misnomer. When you yank the new strings you aren't stretching them to any great degree what you are doing is seating them correctly on the fixed points. The string has to operate within its elastic limit ie if you stretch it by pulling on it or when you pluck it it will return to its original position and tension with the same mass per unit length. If it didn't do so the string simply wouldn't work. All modern strings have an elastic limit way above their operational loadings. String breakage is normally down to a stress point at one of the fixed points but it is possible to pull them until they break.
Having said all that I give them a pull when I put a new set on. If the instrument is well set up it isn't really an issue.
(Shit, it can be difficult to not end a sentence with a preposition!)
