N
Neve1073lover
Inset French Saying Here
More Neck and Head Shaping
I like to do a bit of woodworking every night after work.
I set up the belt sander on its side and took the head face close to flat and just above the finished depth.
Then marked the 15 mm thickness again and did the bottom.
Also did the neck sides and bottom.
I left everything slightly oversize, including the length and body insertion point. This allows me to fine tune later.
Neck Joint:
Head closer to shape:
I will be using the 'tangent' technique to shape the neck. I will explain this later, but you need to get everything as close to straight and flat as possible.
Here's a picture of the neck joint. The line on the body is the 19th fret position. There is a similar line on the neck.
Remember that the body joint needs to slope at 2 degrees, so the body and front edge of the joint must also slope at 2 degrees. Leave enough wood to adjust.
Neck Joint:
