fat_fleet
Swollen Member
so, i'm using the h4n in MTR (multi-track mode) and trying to get the WAV files containing the track data over to my Yamaha AW16G workstation.
problem is, the G will only eat 44.1/16-bit WAVs (imported thru the CD drive).
i've been all over the Zoom's manual, trying to figure out how to select bit rate and depth and it doesn't seem like it can be done in multi-track mode.
i can get the WAVs onto my computer ok. i imported them to audacity, though, to see what the deal was with them. they came up as 44.1/32-bit float (i don't even know what "float" means in this context).
i've been told that audacity can convert bit depth. however, when i do this and export the WAVs from audacity, i then reimport them just to check things out and they pop up as 32-bit-float again. needless to say, i have the same problem when i burn these new files onto a disc and try to get them into the G.
i've heard of software options (dbPoweramp, AA translator etc) that can convert files, but there must be an easier way.
also, to get the files onto my computer, i'm connecting it to a USB slot and selecting the STORAGE option. when i do this (i'm using Vista), a window pops up on my computer screen with auto-play options. i select "transfer music using Media Import", seemingly the most viable option. Roxio Media Import opens up and refuses to recognize the h4n, telling me there are "no devices available for this format (audio)". the zoom simulteneously opens up a screen reading "USB STORAGE" with a Zoom icon and a computer icon and 2 arrows flashing between them (generally indicating interaction between the Zoom and the computer. should those arrows be flashing?). the Zoom, then, is stuck on this screen until i physically disconnect the cable. there seems to be no way to navigate back out of it.
the only way i've found to export the WAVs from the Zoom, is to actually go into the Zoom, which comes up as a storage device on the explore menu, and burn the WAVs directly to a disc. this yields the results detailed above.
also, once i have the files in the computer, i've tried checking the properties tabs to get information on them. the properties tab does not display any rate/depth information except to show the files as 703 kb/s or something like that.
the Zoom itself has a file menu function, where it lists the WAVs comprising the individual tracks in the project (for example TRK1-00.wav, TRK2-00.wav, TRK3-00.wav, TRK4-00.wav for a 4-track recording with no additional virtual tracks). when a track is selected from this menu, a submenu opens up. one of the options is "information". selecting this displays name, date, format, size, and length of the file. when using the Zoom in "stereo" or "4ch" mode, the filetype, bit rate, and depth are listed under "format". in multi-track mode, which i have been using most frequently, only "MONO" appears under format.
anyone out there having insight into this particular thing, i sure would appreciate your help.
thanks.
thanks.
