FALKEN
I am having a small issue with my E-22. When attempting to bias, the left channel was wavering at 10k tone. I knew this would not make for a good recording, and set out to figure out why this was happening, my first thought being a bent reel or a bad pack or something. after several hours of messing around I decided it was either that the tension arms were not positioned properly anymore, or the tape did not have enough tension. (when looking at the tape moving from the takeup reel to the left tension arm, at just the right reflective angle, you could see that the top end of the tape wasn't as taut as the bottom). I looked in my service manual for my E-16 and it says to set the tension on these you need a "tentelometer" which I don't have. So I decided to adjust the tension arms, which was a huge mistake.
I was able to acheive a more consistant level at 10k on the left channel, but not perfect. However, the rest of the machine is now all messed up. The machine uses the tension arms to sense how to move the reels and how hard...so now it does not rewind as fast, and sloowwwws to a halt, and also when you fast wind forward when it gets ti the end of the tape, instead of stopping it speeds up and goes beserk, damaging the tape and sending shreds everwhere. the slightest adjustment in the tension arm height has a dramatic effect on the FF, RW, and breaking mechanisms. In the "best" location for the tension arm roller, RW doesn't even work at all!
what a disaster, I am totally bummed.
