High_Freq
Happy new year.
Has anyone experienced a problem where the reel motors turn in opposite directions to each other on a TASCAM 50-series deck?
I've owned a TASCAM 52-DB for about 15 years, and have enjoyed some good use from it, it has always run pretty well. For those that aren't familiar, it's a two-track 1/4" 15 & 7 1/2 IPS machine whith unbal and balanced ins-outs. It's on the same chassis as the TASCAM 58 1/2' 8-track and shares some parts. Built like a tank. I haven't had a chance to use it much over the last couple of years, but recently went to start it up. Somehow I managed to fry the "spark killer" caps that are attached to the power switch, smoke was pouring out the top. I replaced the switch itself and the caps, so the machine is powered again. (As an aside, the machine is stamped EUR, I'm in AUS, and the spark killer caps were rated 125v - the manual shows these should have been 250v, which is what I replaced them with). While I had the machine opened up I decided to pull the reel motors just in case they were part of the problem, and to clean out any carbon build up on the commutator.
After reassembly, I threaded a tape, hit PLAY. Tape went everywhere. Tried again, in rewind... tape went everywhere. I tested it with empty reels, just by holding the tension arms to get the reels moving. Interesting results:
RW: Supply side - CCW (wrong)
Take-up side - CW (OK)
FFWD: Supply - NIL (brake off, freewheels) - OK? Not sure about this result.
Take-up - CW (wrong)
PLAY: Supply - CCW (OK)
The reel motors are turning very strongly. The capstan motor is fine.
From these results, you can see that in RW and PLAY, the motors are turning in the opposite direction to each other, and that both motors are affected at different times. In FFWD, the supply side motor has the brake off and no power, it just seems to freewheel, which might be as intended, I don't know, but nonetheless the take-up side turns in the wrong direction. I wondered if I'd reassembled a motor with the main casing back-to-front, which might have reversed the magnetic polarity, so I pulled the supply side motor again and reversed the case, but this didn't change the results at all. I also checked the wiring, but this also seems correct; the manual shows that one motor is wired onto the JOINT PCB "white-shield-red" and the other "red-shield-white". I also took photos before I desoldered the motor wires, and I'm confident they were resoldered correctly. I haven't had the guts to reverse the wiring on one to see if it makes a difference.
So, I'm at a loss on this one. The only other piece of conjecture I can offer is this: when the "spark killer" caps in the power switch burnt, I was looming up the tape, and turned the supply side reel by hand, and remember thinking it was quite stiff. Could this have caused a power spike, which damaged something inside the motor (say a capacitor?) Or is there some comparator circuit which detects motor direction which could have been fried? I can't find any clues in the manual.
Any opinions or advice? Thanks.
