acmp 1081 - fully functional or not?
  • Thread starter Thread starter cannabis
  • yes, except for the "pop" it works perfectly
    Votes: 3 50.0%
  • no, it has issues
    Votes: 3 50.0%
  • Total voters
    6
cannabis
cannabis
i know, i know - wrong forum
but most of the interest
in these from the gb
is located here
just to get an idea
of the prevalence
of these problems:
has anybody here
received a fully functional 1081?
(that is, no hum or buzz
or other extraneous noise
with the output gain at max
and the eq switches fully engaged)
or are we just
a few whiners here?
i'll ignore the mic gain switch
"pop"
for now and call it a non-issue
i guess i didn't allow
for the possibility
of multiple units
some working and some not
if you have even one
that works perfectly
answer yes
i have several
and none of them is without hum/buzz
I don't know what a acmp 1081 is, but my acmp 81 has some issues if that helps.:rolleyes:
I don't know that that's even at issue...I think it's pretty well established that they have issues. So do my 73's, but only if I'm using the EQ at 350Hz, which I almost *never* would. Aside from that, sure it's not the quietest pre ever, but it's great on drums.
Frank
Frank
the issue is
do any of them work right?
if so, it would be nice
to find out why
so the rest of us
could fix ours
here's a quote
from another board
I really would like to add a Elma 4130 gain switch and wire it to the board to maintain all the proper gain selections ( resistors on switch, bypass resistors on the board) . Toss the cheap gain switch. This option comes second to the noise in this box. currently I have a 100% failure rate on all my boxes. The noise issue is the primary problem. Good to see that moving the transformer confirmed my findings in most of the noise.
Sure wish we were forewarned about these problems before the purchase. The boxes are unworthy for studio recording. Disclosure disclosure disclosure = integrity, right mates.
I don't see how it's possible to have a fully functional perfect unit when it's a known issue that there are 8 transistors on the boards that were spec'd wrong on the schematic and they need to be changed out before the unit will work correctly.
I think a better poll would be, does anyone have a unit with transistors swapped which is functioning as it should - ie: no noise.
I'm not even going to vote.
Bill put it well. I'm quite sure that the exception would be the 81/83/73's that work well, not the other way around.
The only other thing I'll point out is that all this vitriol after the fact seems unwarranted to me. When we bought into the group buy it was with full knowledge that we really had no idea what we were getting. For my part, I think my 73's are perfectly usable. To each his own I suppose.
Frank
Frank
vitriol?
i think not -
i'm just trying
to find what makes
a usable unit
ok
i have one
with changed transistors
noise is better
but still there
i think it's the
power transformer too
but if there are
units that function perfectly
after the transistor swap
lets hear about it
It's absolutely clear that this is a universal failure in design. Expecting a functional unit is unlikely. It would amount to the Chinese accidentally manufacturing a functioning circuit. In other words, accidentally winning the lottery.
i've read posts
here and elsewhere
about how "awesome"
these pres are
so i guess i infer from this
that they are using
only the preamp stage
without any eq engaged
i guess that's fine
if that's all you expect
but i want the eq's
so i guess if i fix mine
(and i will)
there's no need to
post the fix here
but if there are
lets hear about it
I consider my 81s fully functional after the transistor swap and toroidal transformer re-alignment (i.e. turning it around some)
"Perfectly" is a little tough -- do they sound just like a real 1081? I doubt it (I wouldn't know), but they're eminently usable and add a lot to my little setup.
edit: *much* easier and cheaper than if I had tried the same thing with a kit, for instance, and *way* cheaper than if I had bought something comparable that was retail.
that they are using
but i want the eq's
(and i will)
there's no need to
post the fix here
If you were looking to be an a-hole, there would be no need.
Of course we are all looking for these to be fuctional. The guys who say they work great are using them on ultra loud sources (drums, cabs etc). Almost all of the "awesome" comments disclaim that they are only usable on LOUD sources.
How you come to understand that no one would like to know a fix that brings these into the "entirely usable" camp, I can't quite put together.
yeah, i know that
i'm an asshole
i'm just looking for a fix
and it seemed to me
in reading different boards
that many people are just accepting
of the situation
or think that tnc
is going to fix these
i seriously doubt
that that is going to happen
in light of the huge logistics
and financial considerations
that would entail
i was hoping some of these
arrived in working order
and we could find out
how they are different from the rest
i'm glad antichef feels
his are useable now
but i'd bet there is still
significant noise
with the eq engaged
on the inductor boards
yeah, i know that
i'm an asshole
and it seemed to me
of the situation
or think that tnc
i seriously doubt
that would entail
his are useable now
significant noise
with the eq engaged
I commissioned 2 brand new never turned on ACMP84's yesterday at a friends studio that he is building. They were stone quiet. Hum wise. There is of course a noise floor at higher gain stages. Zero hum even at 360 fully boosted, attenuation wide open, gain full open. No hum.
His 73's were not so lucky, but manageable for his uses - (drummer). There was one QC problem on one of the 73's that will eventually need to be addressed but it will not preclude him from using it.
bp
that's great!
is there anyone near you
that can compare the electronics
of these to the ones with hum
to see if differences exist?
were these late arrivals
that may have been among those
that had the delayed shipping
due to quality problems?
For reference, out of four units I have (2 x 81's and 2 x 84's), there is only one 84 that I would consider "perfect".
It has hum with EQ engaged, 360 Hz boosted, but it is barely audible compared to the noise floor, so I consider that "good enough".
The other preamps have varying degrees of hum with the worst being an 81 with hum at 180 Hz being 40 dB higher than the noise floor.
At some point if I get to it I plan to open them up to see if there are any differences in components.
that's great!
The difference is that the working ones are 84s. They probably don't have a major board located relative to the front right corner at the same offset as that of the transformer from the back right.... That said, I'm starting to wonder if these transformers aren't miswound or something.
it would be helpful
if someone could shoot a pic
of the inside of an 84
to see where things are located
and to see if it uses
the same type eq inductor
and the same toroid ps transformer
as the 81's
Should we be looking at replacing these crap transformers with good ones at this point?
That can't be THAT big a job.
