m audio solaris mic, dmp3 pre amp, mbox 2 pro factory, pro tools, package deal 800
  • Thread starter Thread starter rickmandick
R
rickmandick
open, but never used or registered, includes ilok key
The Mbox 2 Pro is a portable, high-definition audio/MIDI production system that delivers truly professional sound quality. Packing an impressive variety of connection options into a compact interface, Mbox 2 Pro puts powerful multitrack recording and mixing capabilities into your hands, so you can create wherever inspiration strikes. Mbox 2 Pro also includes award-winning, industry-standard Pro Tools LE software and a huge collection of pro effects and instrument plug-ins to get you started creating right away.
Mbox 2 Pro Factory also includes over $1,000 worth of additional professional plug-ins, plus an iLok USB Smart Key to handle your plug-in authorizations.
Hardware
The Mbox 2 Pro is the ultimate high-definition portable Pro Tools LE system, packing a wide-range of analog and digital I/O connections into a mobile audio workstation. Take it wherever inspiration strikes.
Software
Pro Tools software is used in countless professional studios around the world, and includes all the tools you need to easily compose, record, edit, mix, and master your projects with pro results — every time.
Bundled Plugins
In addition to M-Audio Torq LE DJ software and an incredible 8 GB collection of pro-quality loops from industry sound heavyweights Big Fish Audio, Pro Tools software includes a comprehensive bundle of amazing virtual instruments, effects, and utility plug-ins.
Digidesign Mbox 2 Pro Factory Bundle Specifications:
System Requirements
Digidesign-qualified Windows Vista- (32-bit Business or Ultimate), Windows XP- or Mac OS X 10.5-based computer
Minimum 1 GB of RAM
DVD-ROM or equivalent optical drive for software installation
Available FireWire port for Mbox 2 Pro system
Available USB port for iLok USB Smart Key
Mic/Line Inputs 1 & 2
Connector: Two balanced XLR / 1/4" combo jacks with independent gain controls
Mic Phantom Power: 48V
Equivalent Input Noise: -129 dBu
Frequency Response: +/- 0.1 dB
Dynamic Range: 105 dB / 107 dB A-weighted
THD + N (Mic/Line): 0.001% (-100 dB)
THD + N (Mic w/40 dB gain): 0.005% (-86 dB)
Input Sensitivity, Pad off: 1 dBu minimum gain, -39 dBu maximum gain
Input Sensitivity, Pad on: 21 dBu minimum gain, -19 dBu maximum gain
Input Impedance: 3.5 kOhm mic, 10 kOhm line
Line Inputs (1-6)
Connector: Channels 1-4: Four impedance balanced 1/4" jacks. Channel 5-6: One unbalanced stereo 1/4" jack
Frequency Response: +/- 0.25 dB
Dynamic Range: 104 dB / 109 dB A-weighted
THD + N: 0.0015% (-96 dB)
Output Sensitivity: 4 dBV
DI Inputs
Connector: Two unbalanced 1/4" jacks (on front) with independent gain controls
THD + N: 0.008% (-82 dB)
Input Impedance: 5 MOhm
Monitor Outputs
Connector: Two 1/4" impedance balanced jacks
Dynamic Range: 106 dB / 110 dB A-weighted
Output Sensitivity: 6 dBV at max gain 100 kOhm load
Aux Line Inputs 3/4
Connector: Two balanced 1/4" jacks
Dynamic Range: 104 dB / 106 dB A-weighted
THD + N: 0.001% (-100 dB)
Input Sensitivity: 10 dBu minimum gain, -10 dBu maximum gain
Input Impedance: 16 kOhm
Headphone Outputs
Connector: Two 1/4" stereo jacks: one is channel 1&2, one is channel 1&2 or 3&4 (switchable). Independent volume controls.
Output Sensitivity: 2 Vms @ 600 Ohm load, maximum gain
Phono Inputs 3/4 *
Connector: RCA pair
Frequency Response: +/- 1 dB
Dynamic Range: 97 dB / 104 dB A-weighted
THD + N: 0.01 % (-80dB)
Input Sensitivity: -20 dBV minimum gain, -40 dBV maximum gain @ 1 kHz
Input Impedance: 47 kOhm resistive, 150pF capacitive
Digital Specifications
Supported Sample Rates**: 44.1, 48, 88.2, 96 kHz
Maximum Word Length: 24 bit
S/PDIF: RCA jacks
Word Clock: BNC jacks
Host Connection: Two IEEE-1394a (FireWire) jacks.
MIDI: Two 5-pin MIDI DIN connectors
Size / Weight / Power
Height: Including lip: 2.26 inches / 5.74 cm.
Width: 10.28 inches / 26.11 cm.
Depth: Including lip, excluding rear connectors: 9.15 inches / 23.24 cm.
Weight: 3.3 lbs / 1.5 kg.
Power Requirements: Powered off 6-pin IEEE-1394a (FireWire) jack or 9 to 24 Volts DC jack (A/C power adaptor included)
Maximum Power Consumption: 6 Watts
All noise and dynamic range measurements with 20 Hz to 20 kHz bandwidth at 48 kHz sample rates, unless otherwise noted.
ADC measured -60 dBFS at 1 kHz with minimum gain setting; DAC with digital playback at -60 dBFS at 1 kHz.
Frequency response measurements relative to level at 1 kHz.
* RIAA equalization and sensitivity measured at 1 kHz.
** External clock supports up to 48 kHz sample rates
Digidesign Mbox 2 Pro Factory Bundle Features:
Hardware
Professional sound quality
Powered by FireWire* or included power supply
Supports up to 24-bit/96 kHz resolution**
6 simultaneous inputs, 8 simultaneous outputs
4 analog inputs (2 XLR/1/4" TRS combo jacks & 2 ¬" TRS jacks)
6 analog outputs (1/4" jacks)
2 instrument DI inputs on the front panel
2 channels of S/PDIF digital I/O (RCA)
Built-in phono preamp input (RCA) for direct turntable connection
1 MIDI input and output (16 channels in/16 channels out)
MIDI Time Stamping (MTS) support for superior timing and accuracy
BNC Word Clock I/O
Low-latency monitoring
Dedicated studio monitor outputs with volume control
2 stereo headphone outputs with independent volume controls
48V phantom power for condenser microphones
*Requires 6-pin connection for power via FireWire.
**Mbox 2 Pro does not support external sync at 88.2 and 96 kHz sample rates.
New in Pro Tools 8 Software
Award-winning Pro Tools recording, editing, and mixing
48 simultaneous stereo audio tracks (expandable with Toolkit options)
Includes dozens of pro effects processing plug-ins and virtual instruments
Professional MIDI sequencing with dedicated MIDI Editor window
Integrated Score Editor based on award-winning Sibelius notation software
Full Elastic Time and Elastic Pitch to easily adjust timing and pitch on your tracks
Unique Beat Detective LE automatic groove analysis and correction tool
ReWire support for streaming you favorite applications right into Pro Tools
Support for the Digidesign C|24 and Command|8 control surfaces
Huge selection of compatible third-party plug-ins and software options
Works on Windows and Mac computers
Mbox 2 Factory Plug-in Bundle
Cosmonaut Voice
JOEMEEK SC2 Photo Optical Compressor
JOEMEEK VC5 Meequalizer
Moogerfooger 12-Stage Phaser
Moogerfooger Analog Delay
Moogerfooger Lowpass Filter
Moogerfooger Ring Modulator
IMPORTANT: The Factory bundle listed here is the most current bundle; your bundle may include a different assortment of plug-ins depending on when your Pro Tools LE Factory bundle system was purchased.
Virtual Instruments
Boom drum machine and sequencer
DB-33 tonewheel organ emulator with rotating speaker simulation
Mini Grand acoustic grand piano
Vacuum monophonic vacuum tube synthesizer
Xpand!2 multitimbral synth and sample workstation
Structure Free sample player
FXpansion BFD Lite acoustic drum module
Effects, Sound-Processing, Utility Plug-ins
1-Band EQ III
4-Band EQ III
7-Band EQ III
AIR Chorus
AIR Distortion
AIR Dynamic Delay
AIR Enhancer
AIR Ensemble
AIR Filter Gate
AIR Flanger
AIR Frequency Shifter
AIR FuzzWah
AIR KillEQ
AIR Lo-Fi
AIR MultiChorus
AIR Multi-Delay
AIR Nonlinear Reverb
AIR Phaser
AIR Reverb
AIR Spring Reverb
AIR StereoWidth
AIR Talkbox
AIR Vintage Filter
BF76 Compressor
BF Essential Clip Remover
BF Essential Correlation Meter
BF Essential Meter Bridge
BF Essential Noise Meter
Celemony Melodyne Essential
Chorus
Click
Compressor/Limiter
D-Verb
DC Offset Removal
De-Esser
Delay
DigiReWire
Dither
Duplicate
Eleven Free
Expander/Gate
Extra Long Delay II
Flanger
Gain
Invert
Lo-Fi
Long Delay II
Maxim
Medium Delay II
Multi-Tap Delay
Normalize
Ping-Pong Delay
Pitch
Pitch Shift
POWr Dither
Recti-Fi
Reverse
SansAmp
Sci-Fi
Signal Generator
Short Delay II
Slap Delay II
Time Compression Expansion
Time Shift
TL AutoPan
TL InTune
TL MasterMeter
TL Metro
Trim
Vari-Fi
brand new, never used
Serious studio performance at a very Friendly price.
The M-Audio Solaris is alarge-diaphragm condenser microphone that makes a versatile and appealing addition to your project studio's mic locker. The multi-pattern Solaris mic serves as a single or multipurpose mic for personal home studio setups. The Solaris microphone has been painstakingly designed with features usually reserved for more expensive and exotic microphones. Its precision-designed 3-micron diaphragm, selectable polar patterns, bass roll-off filter, and switchable -10dB pad place it firmly in a class previously reserved for high-end imported studio mics. Its innovative, alluring designer look and vintage motif add appeal.
Offering precision circuitry and components, low self-noise, and minimal coloration, the Solaris microphone is the ideal tool for capturing the nuances of vocals, acoustic instruments and other critical source material. With its unparalleled craftsmanship and quality construction, the Solaris delivers professional-quality recordings at an affordable price. Includes case and shockmount. Requires phantom power.
M-Audio Solaris Large-Diaphragm Multi-Pattern Condenser Microphone Features:
Precision-designed 3-micron diaphragm
Selectable polar patterns
Bass roll-off filter
Switchable -10dB pad
Designer look with vintage motif
M-Audio Solaris Large-Diaphragm Multi-Pattern Condenser Microphone Includes:
case, shockmount
brand new never used
An impressive blend of high quality and affordable price.
The M-Audio DMP3 2-Channel Mic Pre/Direct Box gives you XLR microphone and 1/4" instrument inputs. Balanced TRS outputs deliver hum-free professional-quality audio. Low harmonic distortion for ultraclean sound. Exceptional dynamic range allows you to capture all the nuances of the music. High- and low-gain range controls offer up to 66dB of gain. Classic VU meters and clip LEDs help you avoid detrimental levels. Low-cut filters remove unwanted rumble. Features phantom power to accommodate all types of microphones. Phase reverse switch on each channel ensures optimal recordings.
M-Audio DMP3 2-Channel Mic Pre/Direct Box Features:
Especially useful for optimizing signal levels, recording with soundcards, and direct recording of instruments
pics :):):):):):)
im willing to split, got a dwi, so kinda need cash, but ill listen to anything
will seperate, not really looking for trades........... but so far, alot of interest but so far no deal
